[HELP] C# .NET does not support the Bluetooth stack on this device.
  • [HELP] C# .NET does not support the Bluetooth stack on this device.
    Hi at all,
    my brother and I have written this little code to display the Bluetooth devices and have the result in a file using C# (Visual Studio 2008)
    We used the PC with Vista OS, and the plugin is working perfectly with bluetooth adapter, now I put the code on another PC wit XP but does not work ...
    Th PC have Framework 3.5, I have try with all version library inthehand.dll...
    something wrong?
    with other PC the answer of BluetoothRadio.IsSupport is "No Bluetooth Available... did you forget the dongle? ... Press key to continue"
    I attach my code.
    HELP
    The 32Feet.net BT API only supports Windows & Widcomm BT stacks. What BT stack are you using on the second PC (e.g. Toshiba maybe)?
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
      Hi , what do you mean with "stack" ?
      I'm using the same bluetooth adatpter...
        what bluetooth software are you using? is it from Microsoft, Widcomm, Toshiba, etc?
        VoomPC 2
          On Windows 7 with Microsoft Generic Driver it works.
          On Win XP SP3 with Toshiba or Widcoom drivers it doesn't works...
          why????
            widcomm is disabled by default in the 32feet library you need to re-enable it and then recompile.
            openMobile - An open source C# Front End (why choose openMobile?)
            - Always Recruiting Developers -
            Like what you see? Donations are always welcome
              help
              as you can see in the attach, right mouse click on bluetooth icon, configuration, and in the propertier there is the Widecomm... is correct?
                Hi,
                I have installed Windows 7 in VirtualBox, and Work!!!, with XP no!!! Whyyyyyyy!!!
                  you should probably go to the InTheHand forums since they're the ones that built the software, they'll probably be able to give more assistance.
                  VoomPC 2
                    ok I resolv the problem change the forced using XP driver.
                    I have modify the file BTH.inf into Windowx/inf...
                    But Now I have another problem... In RR use Bluesoleil for the phone, and after installation of bluesoleil my program dosn't work...
                    mmmmmmmmmmmmm
                      See my first response to your thread....
                      VoomPC 2
                        mmmmmmmm, and If I try to use the SDK of Bluesoleil?
