Auto dimmer (with GPS or LON/LAT position)
  • Auto dimmer (with GPS or LON/LAT position)
    NEW: Dimmer now supports GPS-Receivers with NMEA protocols.
    remember that this is a beta version, cause i don't had much time to test, so please give me feedback!
    I just coded a program that automatically dims your monitor gamma.
    It locates at your position (lonitude & latitude) where the sun is and dim the monitor if its dark.
    Also you have a manual mode any MANY more really nice features.
    If you set the COM port to "none", the manual lat and long settings are used!
    Click image for larger version
    Mirror of file: AutoAppMart
    If you find any bug please let me know!
    Changelog v3.1b1 since v2.1b2:
    -Added Trigger Box feature to change the dimming mode manually
    -Now Lonitude and Latitude can be set by GUI
    -no dimmer.ini is needed anymore, all set by GUI
    -now an offset can be set for manual sunrise/sunset differences
    -many bugfixes
    Changelog v2.1b2:
    -various fixes
    Changelog v2.1b1:
    -Changed to another sun position algorithm
    -now checks for a valid NMEA device before com port is set
    -no timezone to set anymore. its calculated by longitude
    Changelog v2.0b:
    -Added GPS-Receiver support with NMEA protocol
    -put some settings to the registry instead of the ini file
    -cleaned up the code
    -some other fixes
    Changelog v1.2:
    -Solved hibernation problems, because path to ini file lost
    -ini file now automatically created if it not exists
    Changelog v1.1:
    -custom brightness can be set (20%-50%)
    -Now the Timezone will be considered (please set this in dimmer.ini on utc=)
    -If Centrafuse or other programs change the Brightness, dimmer change it back again
    -All settings like brightness and the last active mode will be saved on exit
    -more stable
    sounds like what my plugin AutoDimmerControl does for CF. Wonder if you had as much trouble converting the lat/lon values to adjusted time values lol. Good work. Put it up on AutoAppMart and i bet it'll receive some love!
    Live mp3Car Facebook Chat
      Updated, mor stable now and it gets darker ;-)
        Looks great. I'll give this a try..
          I'll be happy if i get som feedback ;-)
          thanks!
            Sure can't download it. Attachments are invalid link and the appstore file has 0 bites..?????
              oops...
              works now
                Got it. Works great. Just one question, is it possible to get the LAT and LON from the GPS as the current location?
                  yes that would be an awesome feature as I travel a lot.
                    man thank you, i was searching for somethinglike that for like years!! so simpole, yet so usefull!
                      A GPS reading function would be relly awesome, for me as it would be for you!
                      But, then the program runs really unstable.
                      If there is a fault with the GPS data received from the GPS mouse, the display starts to dim or undim.
                      The same if there is something wrong with the communication.
                      That would be relly annoying.
                      The most stable method is to put in the coordinated manually.
                        currently working on a GPS-Receiver support!!
                        edit: done!
                          Auto Dimmer is now updated with MANY nice features, test it!
                            Does it work in when underground or very dark & cloudy?
                            I know light sensors under $2 do the same thing - whenever it is dark, and without the need for a PC or GPS.
                              Hello,
                              I've been using this for a few years and it works great. I do have one request though. I need to set a truly custom dimming percentage. For my monitor 50% is too dark and 40% is too bright. Is there any way to enter a manual number like 45%?
                              Thanks again!
                              Richard
