program the change resolution on exe.
  • program the change resolution on exe.
    is there a program that will change my res on the lauch and then restore the defult res back once you eiit the program?
    Perhaps this is something for you;
    http://pheonixsoft.virtualave.net/apps/vms/index.html
    white bream
    working on a trilogy: CARGO - UNIGO - MERGO
    CARGO = the Car Computer
    Intel Celeron M, [P]SDC, uBlox GPS, GPRS, WLAN, Silabs FM, RDS, TMC,
    Dual-audio, Onecable TFT, Microsize: 45 x 108 x 168mm (1.8 x 4.3 x 6.6")
      If you are running windows XP, you can automatically switch into 640x480 when an app launches, and then back to your original desktop res after it exits.
      Just right click on the .exe, select properties
      then the compatibility tab
      then check the "run in 640x480" screen resolution.
      That is, assuming 640x480 is the resolution you want to run in :-)
