Perfect Phone For CarPC Interface
  • Perfect Phone For CarPC Interface
    http://www.nokia.com/nokia/0,4879,5778,00.html
    Wow.... Saw this on the Dash PC forum and when for a look.... impresive....
    Can an interface be programed to work with Media Engine or a like - no screen would needed then.
    Full Specifications
    Dual-band EGSM 900/GSM 1800 operation
    Internal SIM card reader
    Ignition sense
    Navi™ wheel
    Bluetooth interface
    RS232 connector
    Modem and fax function via RS232 and Bluetooth interface
    GSM data transfer:
    - HSCSD up to 43.2 kbps
    - GPRS up to 40.2 kbps
    AT command set
    User-guided phone configurations
    Memory for 2 user profiles including contacts, voice tags, and personal settings
    Contacts download from compatible mobile phone supporting Bluetooth technology
    Forwarding of business cards and calendar entries to a compatible phone via either text message or wireless Bluetooth technology
    Audio Features
    Handsfree with excellent audio quality, option to use compatible existing car loudspeakers
    Support fot car radio mute
    Switch between compatible headset supporting Bluetooth technology and car audio
    Ringing tone and speaker volume adjustment with Navi™ wheel
    Switch between normal, silent, and standby modes
    Voice Features
    User-dependent voice dialing, memory for up to 15 names per user profile
    5 user-dependent predefined voice commands per user data set:
    - Replay voice memos
    - Download contacts
    - Replay name tags
    - Replay command tags
    Call Features
    Call initiation:
    - Voice dialing with name tags
    - From phonebook
    - From call registers
    - From favorites list
    - Number dialing
    - Speed dialing
    Accept/reject an incoming call
    Voice call back to SMS sender
    Closed User Group
    Fixed Dialing Number
    Messaging
    Read SMS
    Send predefined SMS templates
    Interfaces Supported
    GSM 900/1800 antenna
    Bluetooth profiles:
    - Object Push
    - Dial-up Networking
    - Fax
    - Serial Port
    - Headset
    - Handsfree
    RS232 connector
    Languages
    Bulgarian, Croatian, Czech, Danish, Dutch, English, Estonian, Finnish, French, German, Greek, Hungarian, Icelandic, Italian, Latvian, Lithuanian, Norwegian, Polish, Portuguese, Romanian, Russian, Serbian, Slovak, Slovenian, Spanish, Swedish, Turkish, Ukrainian
    Sales Package Contents
    Radio Unit TFE-4R
    Display Unit XDW-1R
    Handset HSU-4
    Mounting Plate MKE-1
    Microphone HFM-8
    External HF Speaker SP-2
    Power Cable PCU-4
    Data Cable AD-3
    Installation and User's guides
    Radio Unit TFE-4R
    Weight: 305 g
    Dimensions: 140mm x 106mm x 41mm
    Operating voltage: approximately 10.8V-16V, normally 12V
    Power consumption: Active (call) < 1.5A; Standby < 300mA, Off < 1mA
    Normal operating temperature: -10° C to +55° C
    Intermittent operating temperature: -30° C to +80° C
    Storage temperature: -30° C to +80° C
    Terran
    My Project Site
    beurk!
    Epia M9000, lili 7" vga&touch & 2xTM-7002S compo, camera with reversed image, 2.5" 60 GB, 256Mb DDR, Opus 90W, GPS usb... AND MEDIACRUISER of course!
      Why... I know its not out yet but it will have a blue tooth / rs232 interface with GPRS etc....
      It would certainly enhance the Carpc in a simular way to the Fairlady interface is going to do.
      Terran
      My Project Site
        Another example of this sort of interface can be found in the VDO Dayton Sat Nav systems which interface and control compatible Nokia phones - ie text msgs - calls etc....
        Terran
        My Project Site
          Why not use something more "sexy"...
          Camera phone
          Bluetooth™ wireless technology
          You can keep it in you pant...and use it from the pc via Bluetooth.
          Also for internet acces, e-mail...
            I know you can do that but you could hide the other... also if in the case me you may not be able to use technology like that where you work.
            The 810 could be one with the system... ( Very Matrix reloaded ) how ever I do agree with you.
            Personally I like to have both a carphone and mobile - plus the added advantage is if you have a car phone tied in it could be part of the carPC security system..... along with the GPS... Not sure how yet but thats phase two for me ( if its even possible ).
            Terran
            My Project Site
              i use the nokia 3650. The bluetooth lets me contol winamp
              Falcon cr53 w/ via epia m10000. Nokia 3650 blutooth phone.
              Better than winamp. Click here for qcd player.
                Do any of these phones with GPRS connect to a computer with plain old RS232 for those speeds or is blue tooth the only option.
                I have yet to find a bluetooth device that works flawlessly. Also dont want to have to rely on a bluetooth device. Serial is more widepsread and in embedded devices.
                I just want to send AT commands and get high speed data.
                Doesnt help having a Sony laptop and Sony Erricson phone that dont talk to each other over bluetooh. Incompatible
                  Yeh - if you read on above you'll notice the 810 does have RS232 - thats why I posted it here....
                  Terran
                  My Project Site
                    There's plenty of phone with rs232 option...
                    You could buy a cheap Siemens on ebay hardwire it to you rs232. And use it with your PC for data or phone through AT cmd
                      Nokia 3650 is the best
                      NS - neocar suite
                      http://www.neocarmediacenter.com
                        Don't be so sure. There is so much stuff it can't do over bluetooth, and you end up using the PC as a serial connection over bt instead of a voice gateway/headset. So you don't get access to so much info from the phone.
                        If you just want a fancy remote, you can do it so much cheaper using an Ira, and any spare remote you have lying arround.
                        4x4 in a turbo stylee.
