64-bit Serial / Com Port Splitting Software
  • 64-bit Serial / Com Port Splitting Software
    I'm looking for some freeware 64-bit serial / com port splitting software (I can find 32-bit no probs, but the 64-bit is hard to come by, it seems). I want to split my USB GPS com port between FreeICE and Sygic fleet at the same time....
    Can anyone help?
    2013 Ultima Can Am - Can I fit it with a CarPC?
    MP3Car PC build worklog here
    Facebook full car build here
    Would Franson GpsGate do what you want? I've been running that on 64Bit Win7 and Win8.
    Palm sized ainol MiniPC, 8" Transreflective PRO, Win10, Reverse camera, Dual 10HZ GPS RX's for Speed Display & Sat Nav, FM-DAB & Phone Modules, iDrive interface. T-Screen HVAC control, custom microcontrollers, microcode and FE.
      I have put xport in my dropbox, don't worry its free software and works on 64Bit
      https://www.dropbox.com/s/rw7s1i86kwjp7xb/xport1.52.zip
      just extract all files straight onto C:/xport (make new folder)
      then start xport.exe and once setup you can close it (will go to tray) and it will autostart on system boot
      I use it to split my gps signal for sygic and riderunner
      View my worklog here
        Thanks folks, I knew it was worth a post! I've downloaded both and will see which works best..... I want to have whichever I use to run at startup (ideally as a service), before the FE kicks in. Cheers!
          np problem , if you have questions about xport don't hesitate to pm me
            Is this the same Xport from the Curios tech website?
            http://www.curioustech.net/xport.html
            The site stats that it is 32-bit only and the download I had would not install on my machine with the 64-bit OS
            2002 Chevrolet Avalanche
            Gigabyte Z97 mITX Intel Mobo, 8GB RAM, Intel Core i5-4590S 3.0GHz Proc, 320 GB Hard Drive, Dual 12' VGA HDMI DVI touchscreen monitors,....
            http://www.mp3car.com/show-off-your-...avalanche.html
              Yea Xport itself runs on a 64bit platform but the virtual com port sharing will not work with x64. I use xport to relay data to minicam on my W7 x64 carpc.
              I use GPSGate to share the GPS receiver to 2 virtual com ports. One for xport and the other for centrafuse. This software is free as well.
