mpeg 2 playback is a little choppy
  • mpeg 2 playback is a little choppy
    I have system that has an AMD 2.0 ghz with an nvidia 64mb gtraphic card with 640mb of DDR ram. Mpeg 2 video playback in winamp is a little choppy and not as smooth as the playback is in windows media player. I have Directx 9 already installed and I did just about every config I can do to winamp but it does not change a thing. I also have another AMD 1.3 GHZ with the same config as above except an ATI graghic card and it's playback is just fine. Anyone got any suggestion on what to do?
    Opus case. MB 899 core duo 2.0ghz
    Dual vga out, 400 gb hard drive, Centrefuse front end
    zapco 1000.4 for zapco 6.5 componets
    zapco 1100.1 for 2 13" W6.
    operating system?
    memory?
    winamp3?
    92 Taurus SHO - Daily driver - Epia M10000 80GB 512mb 7" touchscreen, Opus PSU etc
    93 Black SHO - 30mpg cruiser
    90 Silver SHO - 419whp fun/project car, CarPC to come (for tuning)
      Hi Mate,
      Sounds like an nVidia Display Driver issue. I assume the grfx card is not overclocked or anything.
      Make sure you're using the latest drivers, take alook on some of the gamer sites for advice on drivers etc.
      Deffo. sounds like a driver problem though.
      Hope this helps,
      Regards
      Chris
      P.S. CHeck your AGP settings as well...!!!
      1992 Honda Civic EG9 Saloon VTi
      Shuttle XPC SS51G
      Intel 2.4 Ghz
      GeForce 2 GTS Pro 64 m. DDR on a Lilliput 7" T/S
      1024meg PC2700 DDR
      60 Gig 7,200 Drive
      16X DVD
      Haicom H-203-E GPS
      Zippy Mini-EL Keyboard
      Opus 150watt PSU
        I'm using windows XP pro 768DDR 2100 and winamp 2.9. I used the on board 32mb graphic card at first on the shuttle and then I switch to the geforce and have the same problem. The video card is not overclock and I am using the latest drivers. I have an 64mb ATI all in wonder card in another PC that plays back video just fine and it's a slower PC 1.3ghz I will swap them out to see if it makes a difference. Every other program plays back mpeg just fine Windows Media Player, Jet Audio and some others just winamp having the issues
          Thank for the help guyz but I figured it out. Aparntly I needed a mpeg decoder that I found a link to from winamp's forum.
