Release: Frodo Magnifier Application (Download)
  • Release: Frodo Magnifier Application (Download)
    UPDATE:
    Now has installer for ease of use:
    http://www.midsouthextrusion.com/kev...oMagnifier.exe
    UPDATED AGAIN: Version 1.2.2 Bugfix see change log below.
    UPDATED AGAIN: Version 1.2.1 Bugfix see change log below.
    Quick rundown:
    Magnifies area of the screen
    Always on top
    Can be min/max (also with hotkey!)
    Sizable
    Minimizes to system tray.
    Be sure to read the README.TXT !
    EDIT**********************************************
    UPDATE:
    [Version History]
    Version 1.2.2
    Bugfix, (Hotkey was broken)
    Version 1.2.1
    Bugfix, (when minimized to tray, would also minimize to lower left of screen)
    Version 1.2
    Application now minimizes to the system tray.
    Version 1.1
    "Easy Move" Implemented. (Click anywhere in the app to move)
    Width & Height can now be adjusted independently without distortion.
    Multiple levels of zoom added. (1-10)
    Invert colors function added.
    Saves postion and size on exit.
    Version 1.0
    First Release
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Screenshot:
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
      Pretty cool Frodo and handy I might add! Especially for tv out users. But isn't the web saturated with enough of these utilities? Still a great app you got going here. Simplistic, yet useful. Love it!
        I was going for a homegrown, simple implementation. So this is what came out.
        Frodo
        BTW Did you try it ?
        [H]4 Life
        I'm a lesbian too.
        I am for hire!
          Hehe can't complain. When you be in the mode, you gotta code!
            But did you try it ?
            [H]4 Life
            I'm a lesbian too.
            I am for hire!
              If anybody needs more functionality, just ask, if I can code it, I'll try to add it.
              Frodo
              [H]4 Life
              I'm a lesbian too.
              I am for hire!
                Yeah I was fiddling with it for a few minutes but I'm on the laptop and I'm running a high rez so really no need for it there, but I do need it on my tv out in the car. Using a TM-701L at 800x480 so this might come in handy.
                I can't seem to get the hotkey to work. I hit ctrl+m, but no such luck I guess. Also, for us touch screen users, is there a way to make it so that the mouse is the actual magnifier window? I guess what I mean is can you make it so that the mouse looks like a huge magnifier? Also having selectable zooms from 2 to 10 might be cool (not sure how deep you are able to go).
                EDIT: nm, got the hotkey to work. There just happens to be some lag time for me between max/min.
                  Tried it. Works, but seems quite slow. Quite a bit slower than the magnifier built into Windows XP.
                  Shortcut key works fine though.
                  As for features, the most obvious requirement is custom zoom level.
                  Sy
                  GingerPrince
                  Car changed for TVR Griffith 500, so computer de-installed. Using a Dension 100ix w/60Gb HD unit in the interim.
                  Carputer Install - http://www.stuffandting.com/carputer/
                  CarBox Software -- http://www.stuffandting.com/carbox/
                    It works instantly here, but I'll check into it. What are you people running it on ?
                    [H]4 Life
                    I'm a lesbian too.
                    I am for hire!
                      I'm not quite sure what you are asking here, can you elaborate ?
                      I can do that.
                      Also be aware that the app is sizable, so an interim solution would be to make it bigger.
                      [H]4 Life
                      I'm a lesbian too.
                      I am for hire!
                        It starts up fine, it just seems to be jerkier movement than the built-in one. I'm guessing that you blit the whole frame every time, and the built in one maybe moves the image, and just blits the new bit that's been moved into zoom area...if you see what i mean.
                        I'm running an 1800MHz Dell, at work.
                        I think the suggestion about "looks like a big magnifier" means instead of having a stationary window that zooms what's under your mouse, he wants a large magnifying glass to move with the mouse, and zoom in that. Kinda like an app you used to be able to get for the Atari ST!
                        GingerPrince
                          Strange, it's blinding fast on a 1200mhz athlon here.
                          [H]4 Life
                          I'm a lesbian too.
                          I am for hire!
                            Ah, but mine is a Dell though. Could explain a lot
                            GingerPrince
                              Have you compared it side-by-side with the XP version?
                              GingerPrince
