myHTPC software as a front-end
  • myHTPC software as a front-end
    Hi there.
    Apologies if this is a silly question but I was wondering if anybody has considered or is using myHTPC as their front-end to their CarPC systems? I am using this software to great effect on my HTPC (Home Theatre PC) in the living room and could see this being ideal for my proposed Car PC too!
    Given how popular the software is in the HTPC community, I found it strange that it isn't being used in the CARPC community since the two communities are rapidly moving closer and closer together!
    This front-end offers itself perfectly to a touchscreen interface too.
    Is the reason you guys don't seem to use it because:
    a) It just hasn't been introduced to this community yet
    - or -
    b) There is a fundamental reason why this software isn't appropriate for a CARPC?
    If you haven't seen it yet, myHTPC is defiantly worth checking out!!!
    The website is here...
    http://myhtpc.net/
    Here are a couple of screen grabs from the music library section of my implementation at home...
    Best Regards,
    Russ.
    Russ, Russ here...
    1 big issue, no volume control
    Car: 2000 Toyota Celica GT-S
    Mods: Yep
    Carputer: VIA M9000 | Opus 150 | 512MB PC2100 | 60GB Notebook HD | Slim/Slot DVD/CDRW | Audigy2NX | Xenarc 700TSV | (2) DSCustoms DS700HRS (in trunk) | SMC USB 802.11b | CoPilot | DLink FM tuner | Cliffnet
      Hi there and welcome, here ya go.
      http://www.mp3car.com/vbulletin/sear...earchid=152129
      Ah gotta love the power of !
      - 3+ years & still no carputer!
      - Done collecting parts
      - Currently planning setup
        Hi Russ. Nice to talk to you at last! I've been reading posts on this forum for a while now but only just started to contribute.
        Yep! Got me there!! No volume controls but.... do we need them? Wouldn't that be controled directly from the head unit!? That's how I kinda saw this thing working in my set-up anyway!?! Unless I've totally got the wrong end of the stick here! (Which is very possible!)
          I use it on mine and it works great. A few complaints though.
          On a 800 x 600 screen the "back" button doesnt show up on every screen even if you select the checkbox to force it to show. Also that little arrow to scroll up and down the lists is hard to use in touchscreen. And it would be good if they used ID3 tags or at least scrolled the names of the songs when youre looking through the lists. Finally, with my opus the program doesnt allow my computer to shut down if a song is playing.
          These are minor and until something better comes along ill stick with it.
          Also like you said i use my head unit for volume and just turn the computer up about 90%
          Hardware: M10000 / 2.5" 700meg Solid State Drive / 30 gig 7200 rpm HD / DigitalWW 7" LCD / USB Touscreen / X10 Lola Remote / Serial GPS
          Current Project: Turning Nissan Steering Wheel Remote into Joystick to control Frodoplayer
            Hi leenas.
            Cool! Glad to see it can be used then. I've used it extensivly at home and I would imagine it would be pretty awesome in the car too! I especially like the browsing of albums by their cover art!
            Really? As yet, I haven't come across this issue? Are you using the latest version? (I'm sure you probably are!)
            The only other way I could imagine this happening was if your font size for the "submenu item" property was set too high and therefore the buttons become larger. Too many of these large buttons would force the ones at the bottom of the list off the screen. (The back button as you already know is always at the bottom!) It is still there, you just need to scroll down.
            Which brings us to your other point! Your right. The scroll buttons have been flagged up as "a bit fiddly" for touchscreens by a few people. It might help to know that you don't need to press the arrow directly. Anywhere along the entire horizontal line that the arrow appears on will be enough. That may help you a little.
              Yea i read that in the myhtpc forums about the horizontal arrow part. The font size is whatever it comes with as default. For some reason on the page right before now playing (where it lists out all the songs) is where i have the problem with the back button. The main problem is that it doesnt give me an arrow for it to scroll down. The only way to go back from that screen is to use my remote. I think i may try to make the fonts smaller but right now the button sizes are perfect. The thing i would want the most is some sort of scrolling of song names when theyre listed out.
                ah.. i have no headunit, so i need volume control
                Mods: Yep
                  Just to give an update. I changed the font size by 2 and everything now fits perfectly.
                    Yea, I would much rather have a manual volume knob. The Audigy NX USB knob, mounted on the faceplate trim (extended from mainboard) works great with the 2nd release of the drivers from creative (not the DEC 23rd ones, they messed up my system).
                    If I don't have to take my eyes off the road to change the volume, then I'm happy
                    I think I will be running 640x480, will this have problems at that resolution?
                    91 Stealth RT/TT
                    CarPuter: Inspiron 5150 P4 3.0ghz; Built-in WiFi; Deluo GPS; Radio Shark; OBD1; Nostromo Speedpad
                    Audio: Audigy 2 NX; Clarion 500.5 amp; 100.2 center channel amp; Kicker Solo-baric L7 10" Sub
                    Display: Lilliput 7" Touchscreen
                      yeah... only problem w/the audigy2nx is that it doesn't come out of standby properly
                      I've had a conversation going w/creative for the past week...
                      currently using the cd drivers
                      Mods: Yep
                        What does it not do right? (other than the friggin volume being maxed out LOL... It takes a while to re-activate too.)
                        91 Stealth RT/TT
                          the volume thing.. that's it ... but the other issue is that these drivers don't support usb2.0 so dvd playback is a little slow
                          Mods: Yep
                            I use it on a 10.4" 1024x768 touchscreen. I only have a couple complaints. Toucscreen navigation is a little tough in certain spots (little playlist arrow) and the mp3 player is limited. It really needs more simple options like track time and better flowing controls. But Version 2 is supposed to take care of both these.
                            But it works great as a shell to boot other programs. Its skinnable and you can launch any program you want from the main menu. Right now I'm launching 4am music player which I made my own skin for with better touchscreen buttons.
                            Heres my routine: Boot to myHTPC. I launch 4am music player, make a playlist or select a pre-made one. Hit the minimize button and it hides behind myHTPC and brings up the main menu again. Then I can bring up GPS software with the music playing or front/rear cameras (working on cams still). If I need to change mp3 tracks I just drop to myHTPC again and click on the 4am button. The video player in myHTPC isnt bad since I dont need as many options with it. Browsing by picture is nice but it still has the little arrow problem.
                            Theres lots of fun plugins too. I love the myGAMES plugin. It lets you browse and launch any game for about any emulator by picture just like launching a movie.
