Muting MP3s while GPS Navigation Announcement
  • Muting MP3s while GPS Navigation Announcement
    I had one of those clarion autopc's and the one thing I miss most about it is that when a turn came up or the gps system made an announcement, the MP3 player or radio would mute. THis was great and allowed me to actually clearly understand the announcement.
    There must be a way to do this with a carpc.
    ANY IDEAS...
    This would be a great implimentation in to Media Engine or Media Car.
    come on now, anyone, Bueller
      iGuidance does this, although it's just a slight attenuation in the mp3 playing. But it does help hear the voice prompts.
      MikeH
        Ihave been using iguidance. How do you set this?
          You don't. That's my complaint. It's just a very slight attenuation of the playing mp3. It's not quite enough for my taste. I'm going to ask them to make the attenuation user configurable. But it is a nice feature.
          MikeH
            Got it, maybe I just dont notice it hey...
              Routis help says that the volume control is independent of the mixer settings, so just set the wav output at a set amount below the max, and then routis will be able to be heard over whatever you are playing. Haven't tried it out yet, battery died last night after accidentally leaving everything on (whole setup draws 3.3amps, charger which was hooked up only supplies 2.3amps... so that 1 amp dissappeared from the batteries )
              Quote from help file (iGuidance seems to be the same in most respects as routis)
              To Adjust the Guidance Volume Setting
              (i) Information - The Guidance Volume is independent of the mixer volume. You may, for example, playback an .MP3 file at certain volume level setting and hear the guidance prompts at a different level setting.
              91 Stealth RT/TT
              CarPuter: Inspiron 5150 P4 3.0ghz; Built-in WiFi; Deluo GPS; Radio Shark; OBD1; Nostromo Speedpad
              Audio: Audigy 2 NX; Clarion 500.5 amp; 100.2 center channel amp; Kicker Solo-baric L7 10" Sub
              Display: Lilliput 7" Touchscreen
                excellent idea. THanks
