MediaRunner v0.01 BETA DevBuild
  • MediaRunner v0.01 BETA DevBuild
    2/19/04 - Using Microsoft Tablet SDK, the GPS now has handwritting reconization.
    2/5/04 - What do you think of this front page?
    2/3/04 - Upto version 0.03, adding some logging and the mp3 area is working better. If it crashes on you can you please email any screenshots/log files that it generates. Thanks for all the help. Also a heads up, this is pre-beta, I have distributing the development builds which will have bugs in them
    thanks
    Project name: MediaRunner
    Latest version: v0.03
    OS Supported: developing and tested on XP
    Project Type: open source (GNU)
    Supported functions Phase 1: MapPoint, MP3 Player (internal, WinAmp, or WMP9), Video (divx/DVD) (internal most likely aka DirectShow)
    Supported function Phase 2: Camera (webcam), Games (for passenger), calculator, scibble (a notepad without needing a keyboard)
    Skins: your choice
    language: C#
    Currently working:
    - mainscreen/music is fully skinnable with the ability to put the icons anyplace,
    - mp3player (winamp) is almost done, need some testing
    - Video is 90% done, needs some testing. But you can search and play videos
    - MapPoint is half done, you can search and find a location. Need to activate the GPS
    - Security is 90% done, need some testing. It allows you to have a usb keydrive that will activate the program or disable it if unplugged.
    - File Sync, not completed. Will sync your mp3 with your home server most likely using tftp and windows authenication. The home server will need to run the tftp server either on the console or as a NT service.
    - apps not completed
    Dont forget the modify the MediaRunner.exe.config to meet your needs, the readme.txt tells you more.
    I would love to find out people reactions to the program. It is a work in process, and I am going to work on the performance issue.
    New version updated:
    You can download the file at:
    Binary
    http://www.mendis.com/MediaRunner/MediaRunnerv0.03.zip
    Source
    http://www.mendis.com/MediaRunner/Me...rv0.02-src.zip
    Links don't work
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
      Binary
      http://www.mendis.com/MediaRunnerv0.01.zip
      Source
      http://www.mendis.com/MediaRunnerv0.01-src.zip[/QUOTE]
      Same problem here, dead links....?
        Originally posted by frodobaggins
        Links don't work
        Sorry three issues came up, first my primary DNS server needed to restarted, I messed up on the link name, and third I have a permission issue on the source.
        I fixed the first two and will fix the permissions when I get home. But you can get the binaries.
          No ......... still doesn't work
          Mondeo 1.8 Zetec : Epia 800 : 60gb drive : Lilliput 7" VGA : Sapphire USB GPS : Opus 90w : WinXP : Road Runer : Destinator
            Problems with Map Point 2004, and I keep getting this error
            " Application has generated an exception that could not be handled.
            Process id=0xa40 (2624), Thread id=0x30c (780).
            Click OK to terminate the application.
            Click CANCEL to debug the application."
            Just a little FYI
              I get that error on startup
              winamp 5 installed as well as MS framework 1.1.
              Crashes on Execution.
              2011 Nissan Frontier SL
              AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
              OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
                Same thing here
                [H]4 Life
                I'm a lesbian too.
                I am for hire!
                  Seems like people are having trouble running it. Lets see, I think mappoint maybe required (will change of course). Also if it is installed and you are still getting the error, Where do you have it installed? c:\program files\mappoint....
                  thanks
                  sorry from the problems
                    I added a new version .02, which should be better (i hope)
                    Thanks for the feedback.
                      Much better, now it throws a never ending loop of errors
                      [H]4 Life
                      I'm a lesbian too.
                      I am for hire!
                        can you please post the source to either one? i can only download 0.02 binaries
                        Car: 2000 Toyota Celica GT-S
                        Mods: Yep
                        Carputer: VIA M9000 | Opus 150 | 512MB PC2100 | 60GB Notebook HD | Slim/Slot DVD/CDRW | Audigy2NX | Xenarc 700TSV | (2) DSCustoms DS700HRS (in trunk) | SMC USB 802.11b | CoPilot | DLink FM tuner | Cliffnet
                          cool, can you email me the errorlog.
                          thanks.
                          I will post up the source, just want to put up the standard gnu license on it.
                          edit: source is up. check front page
                            thanks.
                            Uhh, there is no error log...
                            [H]4 Life
                            I'm a lesbian too.
                            I am for hire!
                              man this software is bunk
                              "That anit no toung ring thats a marble"
                              Originally posted by menudude
                              thank you all for your help minus the useless post by sjlucky...
