need some help with vb for winamp
  • need some help with vb for winamp
    Below is some vb code. When i enter new song i end restarting current song playing. Anyone know how to stop this? thank you
    Private Sub Text1_Change()
    Dim Filename As String
    Filename = Text1.Text & ".mp3"
    If Len(Text1.Text) = 2 Then Text1.Text = ""
    If Len(Filename) > 0 And FileExists(Filename) Then
    'stop the current song and clear the playlist
    'WinAMP_SendCommandMessage WA_STOP
    'WinAMP_ClearPlaylist
    'open and play the selected file
    WinAMP_OpenFile Filename
    WinAMP_SendCommandMessage WA_PLAY
    'set the track scrollbar info
    hscrlTrackPos.Min = 0
    hscrlTrackPos.Max = WinAMP_GetTrackLength
    hscrlTrackPos.Value = 0
    'other initializations
    cmdPlayPause.Caption = "&Pause"
    tmrScrollUpdate.Enabled = True
    cmdPlayPause.Enabled = True
    End If
    WinAMP_GetStatus
    If WinAMP_GetStatus = "STOPPED" Then WinAMP_ClearPlaylist
    End Sub
    heat cannot be created or destroyed
    here is full project
      Text1_Change will get called every time you enter a character of the song string. It is probably causing confusion for your winamp play function.
