Best way to make Divx videos?
  • Best way to make Divx videos?
    I've been converting to Divx for a few years now and was just curious as to what method and or programs you guys use to get the best quality Divx movies? I've used Dr. Divx for most of mine but was wondering if there is anything better? Has anyone tried SimpleDivx?
    1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
    try GordianKnot, it has all the programs needed (from ripping DVD to compression)
    i wont go into explaining who everything should he set, because it varies from length of the movie but you can shearch DIY on google.
    Danny.
    "If today was perfect, there would be no need for tomorrow."
    My Car Project® ‹== !10.4" Allbrite, touchscreen, epia, 150opus, gps, wireless, sony remote [old] 128x64 Crystalfontz +double din [new]
      "#1 DVD Ripper" look into that. Yeah. its a kinda weird name for a program.
      Just select the framerate of the DVD, check the VOB files u want to copy (arranged in a tree structure), choose the audio track, select your codec (DiVX) go to sleep, and wake up with a DiVX file
      You must have DiVX codec PRO > 5.0 to encode DiVX files, regardless of what software you choose.
      '03 Acura TL PC FINISHED!!
      MP3CAR
        I use the instructions and programs located at www.clonead.co.uk and it has always went very well.
        2005 Ford Focus ST
          how about flaskmpeg, works great for me....
          My carputer
            Easy Divx is really good, it comes with everything you need to rip and compress DVDs.
            http://easydivx.does.it
              AutoGordianKnot. It let's you rip a DVD to DivX in ONE click. Check out http://www.doom9.org for other options (go to the "Guides" section).
              1994 RX-7, EPIA P4-ITX w/ Celeron 2.4 Ghz, Arise PSU, Xenarc 700TSV (new model)
                I've been using CladDVD .net to rip it from the DVD then Dr. Divx to convert to divx. Super DVD Ripper or TMPGEnc to make VCD's. VirtualDub to combine or split Divx. I've tried a bunch of them but found that Dr. Divx to be the easiest way to go.
                  Since we're on this topic, I've got the opposite question.
                  What's the best way anyone's found to move a bunch of assorted MPG and AVI files onto DVD format, with chapter support etc..?
                  ATM, I'm using TMPGenc to convert the files and DVD Author to actually write tyhem to dvd. I'd like to use one program to take all the different formats and bitrates etc. and burn them in one step.
                  Regards,
                  Kris
                  How Much Horsepower Can I have And Still Go To Heaven?
                    Try DrDivX: http://www.divx.com/divx/drdivx/
                      I use smartripper, dvd2avi, avisynth, virtualdub, and then virtualdubmod for the AC3 sound. IN that order
                      Aopen i855GMEm-LFS with Dothan 1.8ghz
                      512mb DDR333
                      Windows XPpro SP2
                        Seconded with modification. Replace smartripper with dvddecriptor.
                        [H]4 Life
                        I'm a lesbian too.
                        I am for hire!
                          BTW, AutoGK is a front end for the dvd2avi+avisynth+virtualdubmod combo mentioned above that analyzes the DVD and handles all the configuration for you. I'm all about the FREE single click solutions.
                            Regards,
                            Kris
                            neodvd ....everything you want and more
                              What ddogg_777 said. But I use XviD. And add Nandub for ABR MP3's from LAME 3.96 & BeSweet. Sometimes I'll keep the AC3 (DVD's & HDTV), rest it all gets downsampled to stereo 128 kbit/sec ABR.
