Tiny Music Embedded 0.9.5 RELEASED!
  • Tiny Music Embedded 0.9.5 RELEASED!
    Version 0.9.5
    I'm proud to release the best version of TME so far!
    PLEASE READ NEXT POST!
    What is new in this release?
    *Keyboard config now works.
    *Directory skipping NOW WORKS! (In this mode, skip buttons skip directories, FF/REW buttons become skip song back/forward.)
    *Minor Config bugs fixed.
    What is planned in the next release?
    *Multiple playlist support.
    *Fix the Runtime error 91 bug, PLEASE READ BELOW.
    TME and the CONFIG program are in one downloadable. As always, make sure to run Config first! There is no install program, just copy where you need it. Windows ME and earlier will have to make sure Visual Basic 6 run time is installed.
    You MUST manually set the location of the settings.ini file with full path name inside the config.ini file otherwise you will get absolutely no where. This is a bug I am working on tackling and have yet to find the solution if there is one. - FIXED! PLEASE READ NEXT POST!
    http://www.experimentalinsanity.com/prog/TME0-9-5.zip
    Tonight's source snapshot:
    http://www.experimentalinsanity.com/...urce6-1-04.zip
    Version 0.9.6
    I'm proud to re-release the better best version of TME so far!
    *Fixed the Runtime error 91 bug.
    *Minor CommPort bugs fixed.
    http://www.experimentalinsanity.com/prog/TME0-9-6.zip
    http://www.experimentalinsanity.com/...rce6-1-04b.zip
