LMF 1.1 Released
  • LMF 1.1 Released
    Here is LMF 1.1, Now for MediaCar and MediaEngine.
    (It's a launch helper for those stubborn apps)
    Code:
    Đ 2004 Kevin Lincecum
    frodo |at| frodoplayer.com
    Launch ************ ! v. 1.1.0
    Usage:
    Make a seperate directory for each app you want to launch.
    (Seperate LMF instances, ie. a whole new directory with all the files in this release.)
    Edit the LMF.INI file with the path to the program you want to launch.
    [MAIN]
    COMMANDLINE=C:\Program Files\XM Satellite Radio\XMMT.exe
    COMMANDLINEOPTIONS=127.0.0.1 /q /s /r2d2
    UNLOAD=FALSE
    You should set UNLOAD=TRUE for MediaCar and set UNLOAD=FALSE for MediaEngine.
    For MediaCar
    Make a folder in the launch folder.
    Example: XM
    Make an XM.JPG in that folder.
    Make and XM.INI in the folder.
    In your XM.INI point it to an instance of LMF.EXE
    Example
    [GENERAL]
    PATH = C:\Program Files\MediaCar\LAUNCH\XM\LMF.EXE
    TryEmbeddedTimeOut = 5
    WindowSearchString=
    For MediaEngine:
    Add LMF.EXE to your applications section in MediaEngine.
    Notes: Closing this app will NOT close the app you launch.
    You must close the called app manually.
    Have Fun,
    Frodo
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    This might be a stupid question, but would this work for CoPilot 7 too?
    2002 Subaru Impreza WRX hatchback - Silver.
    IBM Thinkpad T21 800MHz 256Mb RAM 20Gb HD
    Lilliput 7", CoPilot, MediaCar
    Pyramid Super Blue PB442X 300w 4ch Amp
    Creative SB MP3+ USB
      Why donīt you try?
