Picture Viewer (for developers)
  • Picture Viewer (for developers)
    Hi folks,
    got a picture viewer for you.
    It's nothing special ... basically the same frodo did... except it's completely .NET
    This means, that you have to install the .NET 1.1 runtime (which you already have, if your a PhoCo user).
    For all those of you who are looking for some samples how to write .NET applications I've releasing the source code as well. I've put as many comments into the source, so it should be easy to step trough.
    To configure it, take a look into PicViewer.NET.Config.xml... i think it's mostly self explaining.
    PicViewer.NET
    BTW: I'm not gonna support it... you have the source code... do it yourself
    Skinning to go... VisualDesigner2!
    I'm getting a error message each time I try to start it...
    "Application has generated an exception that could not be handled.
    Process id=0x610 (1552), Thread id=0x598 (1432)"
      Install PhoneControl first and try it again
      Usually, there has to be a setup to apply the access rights...
      <edit>
      Forgot to mention this:
      Copy the Microsoft.DirectX.*.dll from the PhoneControl directory to the PicViewer directory... then it's supposed to work
      </edit>
        Already had PhoneControl installed.....but this worked.
          I beefed it up a bit...
          • If you now plug in a new media (let's say a memory stick, MMC/SD Card), the app will recognize it and start a slide show automatically, in case the device has some pics on it.
          • A path to pictures now can be applied as a command line parameter... with that you may configure various directories.
          • Each given path will be browsed and if it contains subdirectories with pictures, you'll get a listbox to select one of them.
          And... I've put the missing DLLs into the ZIP file
            werd
              werd
              I totally agree... whatever this is supposed to mean
                It is a great little APP but why is it sooo slow? I mean the buttons.. Could you change that so they just dissapear instead of slide out?
                Epia M-800
                160GB HDD
                256MB RAM
                Slim DVD
                Morex Case, M1-ATX
                GPS Mouse
                Bluetooth
                WiFi
                OBD II
                Liliput 7" Touch
                  Way to revive an 8 month old thread there.
                  [H]4 Life
                  I'm a lesbian too.
                  I am for hire!
                    Did you notice this in the first post?
                      I did but it doesn't hurt to ask...
                      Epia M-800
                      160GB HDD
                      256MB RAM
                      Slim DVD
                      Morex Case, M1-ATX
                      GPS Mouse
                      Bluetooth
                      WiFi
                      OBD II
                      Liliput 7" Touch
                        Update!
                        I've added the capability to make PicViewer.NET skinable using VisualDesigner.
                        Also, I've added an configuration dialog (just like in MWI) that will pop up on Alt-C keystroke and a flag whether or not ot use animations when the controlbar appears/disappears .
                        You can download the setup here: PicViewer Setup
                          I cannt download it from http://phoco.net/__Bin/PicViewerSetup.zip,I come from China.who can tell me where i can download ,or someone send it to my email?thanks very much!
                          万分感谢!!
                            Try this one: http://www.zoran-horvat.info/Downloa...iewerSetup.zip
                              thanks,i had download it!
