Adjusting Volume Level According to Master Volume
  • Adjusting Volume Level According to Master Volume
    Alright, I was originally going to use the SPDIF out on the mobo, and go to the Creative DDTS-100, but I decided not to because I didnt like the fact of the external volume and the settings being lost when power is cut.
    Anyway, I have an M10000, and I'm using the audio driver version 3. something (I'll check when I get home), I have the Smart 5.1 enabled on the front speakers, and the Magic 5.1 enabled on the rear speakers, yet the drivers are coded so that the front are set as the master speakers.
    I was looking for a way to make a program that would run in the background, and monitor the front speaker volume level, and when it was changed, have the program change the rear speakers accordingly.
    Would this be possible?
    Also, I tried the newer drivers, and the Smart 5.1 / Magic 5.1 wasnt there, it wouldnt show the front, rear, center, or sub. Just the Master and such.
    What do you guys think? Would it be easy to accomplish?
    This can be done with Girder easily.. With a little playing around I made one on this machine that made the Wave Volume match the Master Volume slider. Since the numbers are different, it wouldn't work on the M10k, but I can make a girder file that will..
    Epia M10000, Custom enclosure, Starvision SP-VGAT, Linksys WUSB54G, Delorme Earthmate, Windows XP
      if you could, that would be awesome!
        Code:
         2004 Kevin Lincecum
         2004 FrodoPlayer.com
        frodo {at|  frodoplayer.com
        Title: MatchVol
        Version: 1.0
        Purpose:
        Matches Wave Volume to Master Volume.
        Usage: Run matchvol.exe
        License: Unlimited for non-commercial use.
        Frodo
        [H]4 Life
        I'm a lesbian too.
        I am for hire!
          Originally posted by frodobaggins
          Code:
           2004 Kevin Lincecum
          Title: MatchVol
          Version: 1.0
          Purpose:
          Frodo
          Sweet, tho I want the rears to be adjusted when the front ones are.
          Anyway I can get the source code?
            I thought your master was front and rears were wave ?
            What exactly do you need ?
            [H]4 Life
            I'm a lesbian too.
            I am for hire!
              Well, theres Front, Wave, Center, Sub, Rear, and so on.
              Heres a link to the install files for the audio drivers I'm using:
              http://www.xtreme2k2.com/AudioDrivers.zip
              Hope it helps
              I want the front and rear speakers to be the same.
                [H]4 Life
                I'm a lesbian too.
                I am for hire!
                  Hmm.. This should be fun figuring this out
                  Its a bit more complicated then I thought it was
                    Alright, I'm an idiot.. I updated to the 5.50a drivers, and ran ADeck, and I could configure it in there... well I'm a dumbass
                    Now if only I could get the sub to stay at max volume..
