Volume control question..
  • Volume control question..
    Is there any way to make the volume controls for my SB Audigy lock to the main volume controls?
    I would like to have my Wave / Optical IN/ and Line In volume match the master volume.
    Frodo made a great program that locked Wave to Main called matchvol.exe
    The purpose for my request, is while in controling my volume i always have to adjust the Wave and others to fine tune the volume.
    I always seem to have the wrong volume. I need to adjust the others so i can have very low background music, or i have to crank up the other volumes when i want to blast it. When i have Wave and Main locked i can achieve this. But it only works on wave
    -Jack
    2006 Chrysler 300C AWD
    Samsung Galaxy Tab In dash
    yes, there is a way the only way I can think of though is to just write a wrapper class around windows mixer controls.. I've done this in my car-software... If ya had VB6 I could send you the code and you can re-shape it to how you see fit.
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
      Well unfortunatley, i am only a hardware person. I know a few coders who might be able to help. If you wouldnt mind i would love to get the source. Thanks
      -Jack
      -Jack
        Const MMSYSERR_NOERROR = 0
        Const MAXPNAMELEN = 32
        Const MIXER_LONG_NAME_CHARS = 64
        Const MIXER_SHORT_NAME_CHARS = 16
        Const MIXER_GETLINEINFOF_COMPONENTTYPE = &H3&
        Const MIXER_GETLINECONTROLSF_ONEBYTYPE = &H2&
        Const MIXER_SETCONTROLDETAILSF_VALUE = &H0&
        Const MIXERLINE_COMPONENTTYPE_DST_FIRST = &H0&
        Const MIXERLINE_COMPONENTTYPE_DST_SPEAKERS = &H4
        Const MIXERCONTROL_CONTROLTYPE_VOLUME = &H50030001
        Private Declare Function mixerOpen Lib "winmm.dll" (phmx As Long, _
        ByVal uMxId As Long, ByVal dwCallback As Long, ByVal dwInstance As Long, _
        ByVal fdwOpen As Long) As Long
        Private Declare Function mixerGetLineInfo Lib "winmm.dll" Alias _
        "mixerGetLineInfoA" (ByVal hmxobj As Long, pmxl As MIXERLINE, _
        ByVal fdwInfo As Long) As Long
        Private Declare Function mixerGetLineControls Lib "winmm.dll" Alias _
        "mixerGetLineControlsA" (ByVal hmxobj As Long, pmxlc As MIXERLINECONTROLS, _
        ByVal fdwControls As Long) As Long
        Private Declare Function mixerSetControlDetails Lib "winmm.dll" (ByVal hmxobj _
        As Long, pmxcd As MIXERCONTROLDETAILS, ByVal fdwDetails As Long) As Long
        Private Declare Function mixerClose Lib "winmm.dll" (ByVal hmx As Long) As Long
        Private Declare Sub CopyMemory Lib "Kernel32" Alias "RtlMoveMemory" _
        (Destination As Any, Source As Any, ByVal length As Long)
        Private Declare Function GlobalAlloc Lib "Kernel32" (ByVal wFlags As Long, _
        ByVal dwBytes As Long) As Long
        Private Declare Function GlobalLock Lib "Kernel32" (ByVal hmem As Long) As Long
        Private Declare Function GlobalFree Lib "Kernel32" (ByVal hmem As Long) As Long
        Private Type MIXERCONTROL
        cbStruct As Long
        dwControlID As Long
        dwControlType As Long
        fdwControl As Long
        cMultipleItems As Long
        szShortName As String * MIXER_SHORT_NAME_CHARS
        szName As String * MIXER_LONG_NAME_CHARS
        lMinimum As Long
        lMaximum As Long
        Reserved(10) As Long
        End Type
        Private Type MIXERCONTROLDETAILS
        cbStruct As Long
        dwControlID As Long
        cChannels As Long
        item As Long
        cbDetails As Long
        paDetails As Long
        End Type
        Private Type MIXERCONTROLDETAILS_UNSIGNED
        dwValue As Long
        End Type
        Private Type MIXERLINE
        cbStruct As Long
        dwDestination As Long
        dwSource As Long
        dwLineID As Long
        fdwLine As Long
        dwUser As Long
        dwComponentType As Long
        cChannels As Long
        cConnections As Long
        cControls As Long
        dwType As Long
        dwDeviceID As Long
        wMid As Integer
        wPid As Integer
        vDriverVersion As Long
        szPname As String * MAXPNAMELEN
        End Type
        Private Type MIXERLINECONTROLS
        cbStruct As Long
        dwLineID As Long
        dwControl As Long
        cControls As Long
        cbmxctrl As Long
        pamxctrl As Long
        End Type
        ' Set the master volume level.
        ' VolumeLevel is the level value in percentage (0 = min, 100 = max)
        ' Returns True if successful
        Function SetVolume(volumelevel As Long) As Boolean
        Dim hmx As Long
        Dim uMixerLine As MIXERLINE
        Dim uMixerControl As MIXERCONTROL
        Dim uMixerLineControls As MIXERLINECONTROLS
        Dim uDetails As MIXERCONTROLDETAILS
        Dim uUnsigned As MIXERCONTROLDETAILS_UNSIGNED
        Dim RetValue As Long
        Dim hmem As Long
        Dim filepath As String
        'Function explanation
        'Sets Volume, saves it to network/volume.txt
        'its a "global" volume so it effects every program
        ' VolumeLevel value must be between 0 and 100
        If volumelevel < 0 Or volumelevel > 100 Then GoTo error
        ' Open the mixer
        RetValue = mixerOpen(hmx, 0, 0, 0, 0)
        If RetValue <> MMSYSERR_NOERROR Then GoTo error
        ' Initialize MIXERLINE structure and call mixerGetLineInfo
        uMixerLine.cbStruct = Len(uMixerLine)
        uMixerLine.dwComponentType = MIXERLINE_COMPONENTTYPE_DST_SPEAKERS
        RetValue = mixerGetLineInfo(hmx, uMixerLine, _
        MIXER_GETLINEINFOF_COMPONENTTYPE)
        ' Initialize MIXERLINECONTROLS strucure and
        ' call mixerGetLineControls
        uMixerLineControls.cbStruct = Len(uMixerLineControls)
        uMixerLineControls.dwLineID = uMixerLine.dwLineID
        uMixerLineControls.dwControl = MIXERCONTROL_CONTROLTYPE_VOLUME
        uMixerLineControls.cControls = 1
        uMixerLineControls.cbmxctrl = Len(uMixerControl)
        ' Allocate a buffer to receive the properties of the master volume control
        ' and put his address into uMixerLineControls.pamxctrl
        hmem = GlobalAlloc(&H40, Len(uMixerControl))
        uMixerLineControls.pamxctrl = GlobalLock(hmem)
        uMixerControl.cbStruct = Len(uMixerControl)
        RetValue = mixerGetLineControls(hmx, uMixerLineControls, _
        MIXER_GETLINECONTROLSF_ONEBYTYPE)
        ' Copy data buffer into the uMixerControl structure
        CopyMemory uMixerControl, ByVal uMixerLineControls.pamxctrl, _
        Len(uMixerControl)
        GlobalFree hmem
        hmem = 0
        uDetails.item = 0
        uDetails.dwControlID = uMixerControl.dwControlID
        uDetails.cbStruct = Len(uDetails)
        uDetails.cbDetails = Len(uUnsigned)
        ' Allocate a buffer in which properties for the volume control are set
        ' and put his address into uDetails.paDetails
        hmem = GlobalAlloc(&H40, Len(uUnsigned))
        uDetails.paDetails = GlobalLock(hmem)
        uDetails.cChannels = 1
        uUnsigned.dwValue = CLng((volumelevel * uMixerControl.lMaximum) / 100)
        CopyMemory ByVal uDetails.paDetails, uUnsigned, Len(uUnsigned)
        ' Set new volume level
        RetValue = mixerSetControlDetails(hmx, uDetails, _
        MIXER_SETCONTROLDETAILSF_VALUE)
        GlobalFree hmem
        hmem = 0
        mixerClose hmx
        ' signal success
        Open App.Path & "/network/volume.txt" For Output As #1
        Write #1, volumelevel
        Close #1
        'vol_shader = 0 at left = 885
        'vol_shader = 100 at 3120
        '2235 * (volumelevel / 100) = twips to add to 885
        'media_search.vol_shader.Left = CInt((volumelevel / 100) * 2235) + 885
        'media_search.vol_shader.Width = 3120 - media_search.vol_shader.Left
        '2625
        ' media_search.img_vol.Width = CInt((volumelevel / 100) * 2235)
        SetVolume = True
        Exit Function
        error:
        ' An error occurred
        ' Release resources
        If hmx <> 0 Then mixerClose hmx
        If hmem Then GlobalFree hmem
        ' signal failure
        SetVolume = False
        End Function
        Function GetVolume()
        Dim volumelevel As Integer
        Open App.Path & "/network/volume.txt" For Input As #1
        Input #1, volumelevel
        Close #1
        'media_search.img_vol.Width = CInt((volumelevel / 100) * 2235)
        GetVolume = Abs(volumelevel)
        End Function
        Via EPIA MII
        512MB RAM
        OEM GPS (embedded)
        nLite WinXP pro on
