The LOW Risk Linux Adventure...
  • The LOW Risk Linux Adventure...
    So, you've got (or are mid planning/assembly of) a carPC. And like so many of us, your plans are becoming more fluid as you learn about more technologies. Which OS, is best, which front end, hardware, etc. the list goes on.
    But installing linux is risky.. The learning curve, walking away from the things you know and love in windows. For some, the risk is just too high to explore further. But what if you could load linux w/o installing it? --yeah actually HAVE run, load, see, learn, play with, explore, fiddle, you name it.. ALL w/o ever enduring the linux install process.
    Well, you can. http://www.frozentech.com/content/livecd.php (I'm partial to KNOPPIX) is a list of "LIVE LINUX CDs".
    Live Linux is a bootable cd w/ linux on it.. LiveLinux 'borrows' your PC's hardware (mem, hd, peripherals, etc) only for the durration that boot.
    "When you're done w/ live linux, remove the cd and reboot."
    With live linux, you can:
    <> save/restore session data to a windows disk or folder.
    <> install/run Linux applications onto/from a windows disk or folder.
    (Though, Linux must be running to use those linux apps)
    FAQ:
    Q: So I just download the CD.IMG of a LiveLinux cd, burn it and boot from it and I have linux running?
    A: Yep!
    Q: Do need to create a Linux partition to keep linux data on?
    A: No, session/configuration/ even linux applications can be kept on your windows partition/file system.
    Q: What does LL install on my system when I boot with it?
    A: Some temporary files are used.. but they're removed at shutdown. --generaly speaking there is no evidence that linux was ever on the PC after a reboot. (but for configuration data that you would have opted to write to disk)
    Q:
    A:
    •Micke
    there are disks like this for SUSE as well
    Signature: [==||========] 20% complete
      Thank you for the link!
      Is there a way to put this image on a CF card and boot from it that way? Is it as simple as burning the image, copying the files to the CF card, and running the card as an IDE drive wtih an adapter?
      Old plans out the window because of an accident .
      Have: M1-ATX, EPIA M10000, 256MB, 60GB 2.5", slim slot load DVD
      Need: Time, HU integration, ideas for Lilli
        ahh i didnt realise this was a list of distros, i thought it was a specific distro made for booting from cd
          Well.. I don't know of any bootable CFs. IF they exist, if you can write to them then yes.. some of these LiveLinuxs are quite small. There may be more help down that link RE: booting from CFs.
          •Micke
            Actually i've used linux to hack my Compaq IA-1 internet appliance. Which involves copying a linux image to a CF card, keep in mind that the images are special for the compaq but still has some good methods and such.
            http://www.ia1hacking.com
            and
            http://www.linux-hacker.net/
            has some great information as well.
            肚子笑痛了
            S60 Install
              that's some good cookie.. thanks
              I don't 'know' this, but I'm guessing boot times would be quicker w/ CF than w/ from an HD or even CD..
              •Micke
                Actually it's surprising, it's not much faster. You would think it would be like lightning. But it's not much faster than a HD. Just has the benefit of being very tiny so it doesnt have to load as much. The whole operating system for my IA1 fits on a 16MB flash card and gives me screen savers, XMMS for playing media, etc.
                肚子笑痛了
                S60 Install
                  wow, that list is extremely long, does anyone have any favorites or versions that have the most features/ useability ?
                  beer replenishment fund
                  mp3car live search
                    <-- has/uses & likes the Knoppix and knoppix-std (Security Tools Distro)
                    If you find that you like knoppix, you can run an option that installs onto HD to make your load perminient.
                    a great bridge from non-linux.noob to full-linux.geek.
                    •Micke
                      Where do you find the option on the Knoppix Live CD that'll let you permanently install Knoppix? I setup a separate partition on my main HD for it, but I can't find the option anywhere.
                      2000 Ford Ranger XLT
                      4.0L V6 OHV
                      (coming sometime soon: fully built carputer with GPS, MP3, DVD, all that good stuff)
                        try mepis
                        it rules all others
                        Mozilla Search Plugin
                          open up a console window and type the following command
                          sudo knoppix-installer
                          i'm pretty sure thats it if not try
                          sudo knoppix installer
                          EPIA MII-1200, 512 MB Ram, Seagate 7200 RPM 160GB hard drive, Orinoco Gold with 5.5 dB external antenna, Lilliput 7" TS, DVD-ROM, M2-ATX, Rikaline 6010 GPS, Running Frodo Player
                          My Truckputer
                            Originally posted by nottastocker
                            try mepis
                            it rules all others
                            I've played with Knoppix a little, and from what I've seen, I like it (I have no idea what I am doing in Linux)
                            What makes MEPIS any better than any of the others?
                            I like knoppix because of the included security features.
                            2000 Subaru OBS
                            Dell P3 @ 900 Mhz
                            7" Lilliput TS w/DigitalWW in-dash mount
                            80GB External HD
                            I am Zero Bitrate....
