Accelerating video?
  • Accelerating video?
    Hi All,
    I am having some difficulty with some Ripped dvds... They were ripped to Xvid, and they play fine on my laptop (P4 2ghz), however, when I try plyaing them in my carputer, the video doesnt keep up with the sound... and depending on the applications running the video can become visually slower...
    Is this codec dependent or what? As far as I know I have the same Kazaa Lite Codec Pack on my CPC and my Laptop...
    The CarPC is an Athlon 1.3ghz, 512mb ram, and it is using the onboard video (the only adapter i could get 800x480 on)...
    I am running NMC, but I dont think it is frontend that is causing this... I also observed that if I run the video in full screen on my laptop (1500x1400 res), then it also slows down a little, but less than is being observed on the carpc.
    Is there any way to fix this?
    Roy
    2005 Range Rover 4.4
    which onboard video chipset is it?
    which sound card are you use?
    which os?
    which codec?
    and so on...
    be more specific...
    did you try ffshow?
    some usb sound card takes more resources...
    etc...
      The hardware you have seems fine to run a DVD...
      Update the BOIS to the latest updates including chipset drivers & video drivers.
      Next what type of interface to the system does your DVD drive have ?
      Lastly, is it out of sync all the time ? Or just on "rough" roads.
      Progress [I will seriously never be done!]
      Via EPIA MII
      512MB RAM
      OEM GPS (embedded)
      nLite WinXP pro on
      1GB Extreme III CF card
      Carnetix 1260 startup/ DC-DC regulator
      Software: Still, re-Writing my existing front end in .Net
        Video is: Sis 740
        Audio: onboard - dunno model Sis 7118 i think
        Windows xp pro sp1
        Xvid codec dont know the exact version
        I didnt try external video player, but i am going to try encoding video with a different codec later to see if it works better......
        Roy
          Bios is updated i believe.... It plays videos fine, just these that i encoded yesterday myself are giving this problem...
          the computer is slightly slow and lagging when running video, and the video is almost slo-mo, while the audio is normal... this with the car stopped...
          it isnt actually playing dvd, it is an avi file from the HD
          Roy
            Thanks for the response Ron,
            Now we got some things to work on, I thought it was playing a DVD from an external drive or something, thinking that maybe the connection to the drive wasnt that great... but where your playing it from an AVI from the HDD, thats make a difference...
            If it plays other compressed video just fine (w/out skipping) then I'd say that the video you compressed didnt compress correctly and that you dont actually have a hardware problem.
            Definatly try another codec, let us know how it worked out.
            Via EPIA MII
            512MB RAM
            OEM GPS (embedded)
            nLite WinXP pro on
              it plays DVDs fine cuz they are not compressed...
              sounds like a video issue... not enough video power
              maybe open in VirtualDub and change the codec settings and resample
              In the early days of DivX this was quite common. One way to improve was to turn off any hardware acceleration for the AUDIO, this way it slowed down the audio. Audio is much easier to decode than the video, thats why the sync is lost.
              Don
                Xvid codec seems to have been the problem for me...
                coding with DivX 5.1.2 or whatever the newest one is worked out fine....
                Roy
