LCD Font
  • LCD Font
    Does anyone know where I can find an LCD font? Like the one the calculators have?
    I want to display the time as a 7-segment display on the app I am writing for the car's main controls!!
    Here a link where you can find some fonts you might like. They have alot of fonts.
    http://www.fontscape.com/explore?5K4
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
      Thanx!!!
        no problem.
        Installed
          Here are some good LCD fonts
          We are, will have and forever will be...
          But not tommorrow!
            That's great!!
            Thank you very much!!!
            Could someone recommend me a way to display time-date with visual basic?? I am having some problems...
              =date() or =time() as the text property of the text boxes
                I've tried that but the time won't update!!!
                This is why I used timers instead!
                Thanx though!!
                  Thanx though!!
                  Use the format function.
                  Code:
                  Format(Now, hh:mm:ss)
                  This was off the top of my head, i may be wrong. 'Now' returns the string of current date and time, the format function formats it in the way you wan to display the info. I believe for date its "dd/MM/yyyy". You can also use 4 M's to get the full title of the month. You will need to use a timer to kep it up to date.
                  But not tommorrow!
                    Well I did use a timer for the time, it seems I will have to do the same for the date!!
                    Is it possible instead of 15:46 to display 3:46 ?
                      try the following:
                      Format(Time, "Medium Time")
                      This should show the current time in 12 hour format
                        That works!!
                        Thanx...
