Favorite Front End
  • Favorite Front End
    The list of front ends is growing. What are your favorites and why? I'm using an xm direct, and cable, INav, 8" Lilliput, pci radio/tv tuner which has the BT878 chip, and soon to have a reverse cam. I also neep mp3 and dvd support. Which front end would be the best for use with this hardware and the touch screen.
    I've tested MMC and like it, but there is no support for the radio or nav.. yet.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Right now your best bet would be FrodoPlayer, but I am a little biased.
    That may change in the future as the other developers impliment new features.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
      Maybe this front end isnt known but i use www.xlobby.com It's i high customizable piece of software witch allows you to make your own front end.
      You get the program and it has a simple standard skin. you can work around that or make a whole nw skin like i did. I use it for care use and for HTPC use also.
      I'll think about posten my program with the skin here.
      You'll need to be busy with it to make a nice skin, but after a few hours working with it, you get the experience like programming :-)
      The program uses winamp, zoomplayer and net.framework to run.
      ThE ScReW's CarPuter :-)
        please post some screen shots, Do you have GPS? If so how would you use it with xlobby
        [M10K][TinyXP][Roadrunner Frontend][OEM Enclosure]
        [iGmon]
        Download MP3 MixTapes
          the only one that I had NOT tested is CNS
          except it, I have to say the best is FP1.09, that's why I use it and code plugins for it
            someone should make a list of all the carpc softwares, it's more than dorzen now
            I will do it if I have time
              I kind of prefer Media Engine. Probably since I've been experimenting with it since it's v1.7 days.
              AutoPC: M10k, WinXP, gps, wifi, 80GB HD, dvd-RW. SB mp3+
              MediaEngine front end, map monkey, netstumbler.
              gps mouse is on the fritz.....stupid technology
                It's already been done.
                http://www.mp3car.com/vbulletin/showthread.php?t=34218
                Installed
                Asus A7N8X-VM - AMD Mobile Athlon 2400
                512 Ram - 60GB HD - Opus 150w
                Lilliput 7" - Rikaline 6010
                [00000000000001100010-] 98% Completed
                Check Out My Install!!!
                  Well, right now I use Frdoplayer for everything. This may change with the development of AIMEE
                  PowerVoice v1 | NaviVoice Source
                  GammaControl v2.4
                  SKINbedder v3
                  1995 Lexus SC300
                    Frodoplayer right now. AIMEE does sound really promising. I also like Neo Media Center very much, been playing around with it for a while and its great.
                    Frodoplayer is going to have some really good competition soon.
                    Installed
                      Here are 2 simple screen shots the first is a beta of my carputer software and the second is my HTPC software ( it's in dutch )
                        Originally posted by Quattro-A4
                        not enough, the desktop ones which can be skined should be count in
                        like frodo's midiaprotral, meedio....
                          Then post in the thread. He will add them.
                          [H]4 Life
                          I'm a lesbian too.
                          I am for hire!
                            hows the GPS work?screenshots of that??
                            [iGmon]
                              If i hit gps, destinator 3 start full screen, that's all and thats good
