Syncronising Music and DIVX
  • Syncronising Music and DIVX
    I am wondering what applications people are using to sync files on the CarPC. I have a CarPC with Wifi and looking for a suitable application. Whats best?
    There was some discussion, try searching... I know somepeople use Microsoft Offline Folders, but i'm not sure how it is setup... it is included in XP I believe...
    Roy
    2005 Range Rover 4.4
      I use a program called Replicator from Karenware.com which works wonders. Very very easy to use. You can either use it standalone or it's included with Frodoplayer.
      肚子笑痛了
      S60 Install
        Karenware replicator works great to get the initial load of stuff over... after that Offline folders work well although you do have a little more overhead on your system...
          how does this offline folder stuff work?
          [M10K][TinyXP][Roadrunner Frontend][OEM Enclosure]
          [iGmon]
          Download MP3 MixTapes
            You might be fine for MP3's but you're going to have a heck of a time with divx. Well, that depends on the size. Mine are around 700-800 megs so your looking at 20-30mins a peice. A long time to sit with the engine running in your driveway.
            I use a removable HD that fits in a 5 1/4 bay. Slide it out and slide it into my home desktop, drag the files over then take the HD with me next time I leave and put it back in the car.
              There is a program out there called "ghost files"
              made by http://www.lowrieweb.com/ghostfiles.htm ...it $30 but there is a trial.
              I have had this program for quite sometime and I use to use it to replicate stuff over to my webserver (for website back up purposes)
              all it requires is some drive mappings ...works wonderfully
              2002 Suzuki Aerio Sedan ...NOT the stupid wagon
                basically you have to have a mapped drive.... you then right click on it.. and say make files and folders available offline
                something like that
                do a search in help if you dont see it...
                  This is the program I use and I highly recommend it compared to M$oft's offline folders
                  http://allwaysync.com/
                  and its Free.
                  carputer: in progress
                  Laptop install
                    and its Free.
                    Thanks for pointing to allwaysync, i'm gonna try this now and tell you how it went
                      http://www.mp3car.com/vbulletin/showthread.php?t=43914
                      Quick! To the Popemobile!
                        How about XXCOPY32 in a batch file?!
                        It has a "clone" switch that does it all for you!
                        http://www.xxcopy.com/index.htm
