Destinator 3 SDK.. what format to use ?
  • Destinator 3 SDK.. what format to use ?
    Lo peeps, still here working on a frontend and learning VB at the same time. The examples in the sdk read me arent in VB, so I was hoping some one could help me out.. .Also I would like help or info on how to calc the speed..
    example
    GetCurrentCarPosition
    Detects current car position.
    HRESULT GetCurrentCarPosition(IDestPoint* pPoint)
    Parameter:
    pPoint
    [in] coordinates of the current car position.
    Return value:
    Returns S_OK on success or an error HRESULT on failure.
    unsure what this statement would look like in vb..
    thanks
    CdR
    Follow me on Twitter
    http://www.FreeICE.co.uk
    Something like this?
    Code:
                    'Get current position
                    Dim dis As DESTDLLLib.DestPoint
                    Set dis = New DESTDLLLib.DestPoint
                    Set dis = d.GetCurrentCarPosition
                    dis.Description = "whatever"
                    'Then to add the position as a favourite
                    Dim fName As String
                    fName = "Auto Alert 1"
                    If Not dis.Description = "" Then
                    d.AddPointToFavoritFolder fName, dis
    Laidback
    The ultimate CarPC - Wow!
      thanks fella.. I will have a play l8r..
      heres a current screen shot of it atm.. its getting there slowly :-)
      CdR
        Lookin' good Steve
        Don't forget to make it skinnable (VB for dummies, chapter 14, section 5)
        DC UK Forum
          yeah it will be a good couple of weeks at least, but its going to be skinable when i've finished :-) just getting all the code right first :-)
          CdR
            Cool
            I think it would be a big step forward if we can all customise our D3 skins to match our frontend skins
            DC UK Forum
              more problems..
              ok.. i'm trying to grab the street id's from a city id.. but unsure of the syntax I should be using.. please help :-)
              heres what is says
              Retrieves an array of street IDs for a city. The city must be defined by its ID and this value must
              be greater or equal then 0 and less than number of cities in the map minus 1. The number of cities
              for the map can be detected by get_CityCount method.
              HRESULT GetArrayOfStreetsIDForCity(long nCityID, IDestIDArray**
              ppIDestIDArray)
              Parameter:
              nCityID
              [in] the city ID.
              ppIDestIDArray
              [out, retval] the array of street IDs.
              Return value:
              So lets say I do the following
              Dim street() As Variant
              Dim CityID as Long
              Dim Result as Long
              CityID = "17"
              Result = g_Dest.GetArrayOfStreetsIDForCity(CityID,street())
              This doesnt work of course. .so I tried this..
              Street = Array(g_Dest.GetArrayOfStreetsIDForCity(CityID))
              that didnt work either. .lol
              pointers would be helpful..
              cheers
              CdR
                its ok sussed it :-)
                  where can I find the D3 SDK and example?
                    The guys at destinator sent me a link to the SDK a few weeks ago, but the link won't work
                      veetid u have a pm
                        Is the SDK that Skuzzle2 has the latest version?
                        Installed.
                        -GPSSecure- - GPS Tracking
