anyone use DLPORTIO.dll (Port I/O Driver)
  • anyone use DLPORTIO.dll (Port I/O Driver)
    Using the Port I/O Driver driver from http://www.driverlinx.com/ for LCD integration. Everything works fine, except it crashes coming out of hibernation. Anyone else used this and gotten it to work with hibernation? I am using Interop DLLimport in C# to make function calls...
    david
    If you don't find an answer to this, you might try that one: http://www.logix4u.net/
    It's more or less the same and I can't say for sure whether it's hibernate aware or not. At least, you'll get the source code in which you might be able to handle the hibernate messages.
    Skinning to go... VisualDesigner2!
      works great, even in hibernation!!!
      david
        Sorry to drag this one up again but I'm having the same problem was the fix straight forward or did it involve some programing?
