I have speech recogniton working with 1500 cd's
  • I have speech recogniton working with 1500 cd's
    Hello I'm Jeff. I have voice recognition working with 1500 cd's. I'm using MS SAPI 5.1, C++, Perl, and my own XML data structure. I can call up all but 3-4 cd's out of 1500. I wrote a perl program to make my artist and album names pronounceable. It corrected the pronunciation 90% or the remaining names automatically. I only had to edit less then 1% of the pronunciations by hand. E.g. I changed ac-dc to "a c d c" After the artist is recognized you can speak the album name or "open album number <nn>" e.g. "open album number two" I also figured out a very easy solution to make the remaining 1% pronounceable.
    I can call up any cd with better then 99% accuracy in a quiet room with a hands-free, Crown microphone. I can also command my jukebox software with better then 90% accuracy while standing 20 feet away with the Crown microphone. My software also loads fast. When it starts up it loads data for about 15,000 songs from a 3.5MB in less than 2 seconds. My software should easily be able to work with 100,000 songs or 10,000 cd's.
    I'm using a professional omni-directional, electret condenser, pressure zone microphone by Crown connected to a mini-mixer with 70dB of gain, balanced inputs, and 48V phantom power.
    In a noisy car I can get better then 90% accuracy using a good headset mic. With the Crown accuracy is probably 70% in a noisy car.
    I'm interested in trading my knowledge with some people here. Is anyone here as far as I am in their speech recognition software development? I've spent about a year on and off developing my jukebox system.
    "There is one thing stronger than all the armies in the world, and that is an idea whose time has come." - Victor Hugo, 1802-1885
    you wana talk to 01331, he's coded a voice program to be used with many front ends.
    CarPC status: iPod, 3,456,217 songs so **** you
      0l33l
      CarPC install is starting to come along again...
        I wrote a voice interface also built with the MS voice SDK to call up songs by artist and song name a couple years ago, but I have yet to run it in the car with a recognition level I can live with. It's incredible for use in a media center PC and I've had similar experience to you getting well over 90% recognition in the house when its quiet using a cheap *** webcam mic from across the room, but in the car it just sucks.
        I used an array microphone in the car, but when driving with road and engine noise, I can maybe get to 70% recognition only if I yell real loud. It would be great if you could actually get good recognition wihout a headset, but the other problem I have is that I can't remember the exact name of most of my songs half the time. I added a feature to play a random song by a specified artist if you just say the artists name and a visual confirmation of what is being recognized, but even with that I still find I rarly want to use the voice interface for any reason other then to impress my friends. I just find it easier to just pick a song from a list after gesturing in a couple of the first few characters then to try and remember the exact pronunciation of everything, particularly when recoginition is going to fail often. That and I look like a tool when I'm at a stop light yelling song names at my car
        I would still like to hear more about how you programmatically corrected pronunciation, the only thing I did was convert numbers and remove some punctuation, but found this left a few artists and songs that were pronounced differently then what I thought they should be. However, the real issue doesn't seem to be one that can be solved by software, it seems like microphone and noise cancellation technology just isn't at a level good enough to get clean sounds into the system.
        StreetDeck.com Developer (I am Chuck)
        Get StreetDeck at http://www.streetdeck.com
        The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
          I'm working on Voice Reco. I'd be interested in how you were able to grab / edit all the artist / songname's.
          I have a system designed for use in vehicle's that compare's what the system heard with actual data (it can compare fragments of sounds also) The fragements of sounds compare sequence is interesting and effective because typically in a car the microphone will never get the full sound that you said. This is due to the noisey envirnment. Noise can occur at unknown times and it almost impossible to completely rule out..
          For example, you are trying to play the song "Inbucus - Megalomaniac" when you are 3/4 of the way through a semi honks a horn and your microphone picks up that noise.. Typically SAPI 5.1 would hear that noise and bounce back a FalseStatement because the speach pattern of: Incubus - Megalon*HONK* doesnt compare to ithe actual patter of Incubus - Megalomaniac.
          My software hooks into the SAPI 5.1 Hypothesis event and monitors what SAPI is hearing, it remembers and compares song name's with song name's and artist's with artist's... it looks for wild cards as well.. if it heard something 75% or more it then continues to find a better match of a better match is found it continues to look for an even better match. If no better match is found, then the 75% match is chosen.
          This system has dramatically improved voice recognition, I beleive this with noise reducing microphones could be a great start.
          However, my problem exists with song name / artist... Every music file has a different format and it's a daunting task to write code to format each .mp3.. but from this thread it looks like this has been done for us..
          This intregue's me, and I'm hoping you can put that code up here so we can use it with some of our system's.
          I would be willing to throw my comparison code up, I will try and do this later tonight when I'm on the machine that actually has the code.
          Progress [I will seriously never be done!]
          Via EPIA MII
          512MB RAM
          OEM GPS (embedded)
          nLite WinXP pro on
          1GB Extreme III CF card
          Carnetix 1260 startup/ DC-DC regulator
          Software: Still, re-Writing my existing front end in .Net
            perl code for making pronounceable names
            Here's my Perl code. You'll need to know Perl to use it. All the code below has been tested.
            # try to make the string $s pronounceable by the computer
            # - usage $s = makePronounceableName($s);
            sub makePronounceableName
            my $key;
            my $val;
            my $s = $_[0];
            # delete matching braces, parenthesis and everything inside
            $s =~ s/\(.*?\)//g;
            $s =~ s/\[.*?\]//g;
            $s =~ s/\{.*?\}//g;
            # replace ampersands
            $s =~ s/\&/and/g;
            # replace abbreviations
            $s =~ s/vol\./volume/;
            $s =~ s/ vol / volume /;
            $s =~ s/no\./number/;
            $s =~ s/op\./opus/;
            $s =~ s/Mr\. /Mister /;
            # replace some roman numerals
            $s =~ s/ iv / four /;
            $s =~ s/ iv$/ four/;
            $s =~ s/ iii / three /;
            $s =~ s/ iii$/ three/;
            $s =~ s/ ii / two /;
            $s =~ s/ ii$/ two/;
            $s =~ s/volume i /volume one /;
            # replace non-alphanumerics with few exceptions
            $s =~ s/[^0-9a-zA-Z\b\'\,]/ /g;
            # replace two or more adjacent whitespace chars
            # spell numbers with whitespace on either side or ^ or $
            # - first check for whitespace
            my %number_list = ( "0", "zero", "1", "one", "2", "two", "3", "three",
            "4", "four", "5", "five", "6", "six", "7", "seven",
            "8", "eight", "9", "nine", "10", "ten"
            foreach $key (keys (%number_list))
            $val = $number_list{$key};
            $s =~ s/^($key)\s/$val /;
            $s =~ s/\s($key)$/ $val/;
            $s =~ s/\s($key)\s/ $val /;
            return $s;
            # TEST CODE
            # - "3 Doors Down" becomes "three Doors Down" (spell out numbers)
            # - singles digit replacement is fine for now
            # - "Beethoven (1770-1827)" becomes "Beethoven" (remove all parenthesis and their contents)
            # - "Absolutely_ Best Of ABC" becomes "Absolutely Best Of ABC" (remove all non-alphabetic characters)
            # - "Private Times...And The Whole 9!" becomes "Private Times And The Whole nine"
            # - spell out abbreviations: "vol." -> "volume"
            # - replace "&" with "and"
            sub test_makePronounceableName
            my @testlist = ("Zero 7",
            "3 Doors Down",
            "50 cent & two pennies",
            "_compilations",
            "Absolutely_ Best Of ABC",
            "Beethoven (1770-1827)",
            "Private Times...And The Whole 9!",
            "hello 5 hello",
            "van halen ii",
            "van halen ii ",
            "hello (uu) [256] )}] tt{x} 4 44 5x x5 x5x (xx) (yy) ({["
            # try to use "./testnames.txt"
            #my $testlist = `cat ./testnames.txt`;
            [email protected] = split /\n/, $testlist;
            my $name;
            my $pronounceable_name;
            foreach $name (@testlist)
            $pronounceable_name = makePronounceableName($name);
            print "'$name' => '$pronounceable_name'\n";
              reading song data
              I like this solution. Thanks. I'm going to use this solution in my system.
              Here is my solution:
              1. Make sure you id3 tags are correct. If they are not re-rip the cd to get the proper cddb information
              2. Use perl to read all the id3 tag info
              3. Write all your id3 info to a data file
              4. Have your voice software read this data file at startup
              - My C++ software reads in data for 15,000 songs in less than 2 seconds.
                Hi. This is one of the features that I was going to implement into NaviVoice. I just need some support from Frodo, to make a program that dumps all the artis/album names into a text file, and to make a feature to send search parameters to Frodoplayer
                PowerVoice v1 | NaviVoice Source
                GammaControl v2.4
                SKINbedder v3
                1995 Lexus SC300
                  Could you read the Album/Arthis info directly from FP's JET DB? Also, could you fake the search interface by sending keystrokes?
                  2004 4runner
                    He could definately access the DB provided Frodoplayer doesn't lock it or something like that.
                    Doesn't fpwebserver allow you to send searches to it?
                      Originally I though I would only do artist and album names, but since you guys have good results with song names too, I'm gonna do those too. Looks like I'm gonna have to learn how to acess DB from Delphi. And yes, I could definately use a hidden web browser (not IE for those that removed it) to play the songs. But this is a few releases away.
                      GammaControl v2.4
                      SKINbedder v3
                      1995 Lexus SC300
                        As far as Artist / Songname I find that the orginazation is highly un formatted. I realize you can find the artist and songname from either the file name or the ID3 tags but coding this can be a logical nightmare !!
                        It would be nice to get some functions already written out on the web
                        Via EPIA MII
                        512MB RAM
                        OEM GPS (embedded)
                        nLite WinXP pro on
                          I know what you mean. I looked at Frodo's DB, and some songs have things in (), etc :|
                          GammaControl v2.4
                          SKINbedder v3
                          1995 Lexus SC300
                            If you use xml the data is very easy to define and process. There are lots of libraries in just about every language to read and write xml. Just convert the id3 info into xml and throw it into one big file. That is what I am doing.
                              you can ask frodoplayer to send you the list in xml
                              [H]4 Life
                              I'm a lesbian too.
                              I am for hire!
