irman isn't loading any playlist
  • irman isn't loading any playlist
    I have an Irman remote and it works fine however i can't laod any playlist by remote
    i can by keyboard. Where do i go wrong?
    I have a map "playlist" in the winamp dir and the playlists are numberd as 001 , 002 , ....
    PETER - THE NETHERLANDS - DEVENTER
    sproggy 2.8,epia c3-800,20Gb 2.5", 5.6"lcd,touchscreen.
    Make sure you have set the playlist location, and programmed the remote buttons for load playlist, prev playlist, next playlist.
    Try naming the playlists 1.m3u 2.m3u etc rather than 001.m3u 002.m3u
    What do you mean by a 'map playlist'?
    A friend of mine has written a program that scans directorys and builds playlists (1 per directory)sorting them and naming them either with the directory name or with a number for the irman plugin. It also outputs a txt file showing all playlists, sorted alphabetically. This is great if you have your mp3 arranged in one directory per album.
      I had this problem too. I found that the uir plugin playlist feature only works on Winamp 2.65 or lower. Any version higher than that (for my three machines I tried it on) all lock up when you go to change lists.
      It is a pain. Has anyone heard any news of a uir plugin for winamp 3?
      How different is it I wonder....
      Bj
      BjBlaster! Car MP3 & Carputer!
      bjblaster.com
      "The solution to one problem is only the beginning of another"
        sam 66, i have set the playlist location in the ini file but the only key i can program is the load playlist. with the map playlist i mean the dir where i put the playlist's in.
        The program from your friend sounds good to my and i like more info if posible.I wil change the playlist into 1.m3u and 2.m3u ...
        i will let you know if it works
        BJ , I have winamp 2.09 and 2.05 and still it's working so?????
        i'm wondering if it's just on 2.65 and higher
        thanks you all
          Sam 66 thanks it's working.
          However only for the numbers 0....9 not above it .Am i doing somthing wrong again or is the limit from the plugin that you can only select 10 playlist's?
          peter3
            Which plugin do you have as there are several for the UIR/Ir man device. I suspect you may be running a different than me.
            I have about 250 playlists and it works ok so more than 10 shouldn't be a problem.
            It should also work with all versions of Winamp, I'm using v2.72 and it's fine.
              Sam 66 I have the PE1PUY IfraRed Plugin
              v 2.2 (gen_ir.dll)
              If you have a diferend one please let me know and if posible you can mail me it to me?
              peter3@pveen.demon.nl
              The Netherlands
                I have v2.53 but don't have the install file anymore.
                Did a search and found
                http://www.geocities.com/SiliconVall.../download.html
                Try that, if for some reason the download won't work then let me know and I'll try to find one that does.
                  thanks Sam 66
                  i'f found the site and downloaded it . I'l try it and let you know if it works for me
                  thanks
                  peter
                    Sam 66 I'T WORKS THANKS FOR HELPING ME OUT
