BartPE
  • BartPE
    Just stumbled across this: -
    http://www.nu2.nu/pebuilder/
    Seems to let you create a bootable Windows XP environment on a single CDROM (ie < 700Mb). Anyone ever considered using this for a carputer?
    - Given it boots off read-only media it'd presumably remove the need for clean shutdown.
    - Looks like you can configure "plugins" for it, so for example a Frodoplayer plugin could likely be made for it.
    - It's made to boot off CDROM but I guess it could also be made to boot off memory stick/card etc.
    Not used it myself, but tempted to give it a go. Just wondered if anyone had already considered it?
    I'm guessing though that it doesn't include Windows media etc by default as it's a rescue type disk, but I see no reason why the correct DLLs couldn't be added to it?
    GingerPrince
    Car changed for TVR Griffith 500, so computer de-installed. Using a Dension 100ix w/60Gb HD unit in the interim.
    Carputer Install - http://www.stuffandting.com/carputer/
    CarBox Software -- http://www.stuffandting.com/carbox/
    Yesterday, I had thought of the very same.
    This is what I already found out:
    - booting from USB-devices (stick, USB-cdrom, etc) is not possible.
    - booting from hard disk seems to be possible, but I don't know yet if the used partition is read-only, or at least there are no open files, which have to be synced.
    Just search for "pehdinst cmd" (PE-HD-installer) to get an idea on what it does.
    I hope I can configure the PE-installation to use my PSone LCD on my VIA Eden board in the car and also that the booting process is fast, when using a hard drive.
      You'd use a slipstreamed Windows install that includes drivers, software, etc along with BartPE.
      The problem with BartPE is that you're booting from a CD which doesn't read as fast as your hard drive. You also wouldn't be able to tweak it the way you want (your favorite desktop or screensaver, specific Windows behaviors like single-clicking, icon configurations, etc.) and that sort of thing.
      However, you could possibly use a BartPE image on a CF drive, perhaps. I don't know if that's ever been attempted or not.
      How about the Wiki?
        I use the BartPE for doing tech and diagnostic work on systems and it works well and I have yeat to try custimizing it but you are suppose to be able to customize it
          yeah, you can customize it quite extensively. theres the 911 cd forums that have tons of plugins for it. WinPE loads very slowly, you guys probably won't like it for in car computer use
          CarPC install is starting to come along again...
            I want to try a copy of Damn Small Linux in the car...
            Zen Fat Loss
              Yeah I've used it since I posted the original message. It is good for rescue disk et al, but it does take quite a while to boot - even booting directly off hard disk (which incidentally you can do to get about a 150Mb OS footprint).
              Problem is it has to do hardware detection because it doesn't already now what you've got. Now, if there were some way to pre-configure the hardware, like I dunno import some registry settings into the image or something? Haven't had time to play more.
              Definately needs work though, but remember it can boot off hard disk etc.
              GingerPrince
                and what apps would you run on it?
