Disabling safe mode in Windows ME?
  • Disabling safe mode in Windows ME?
    Whats the method to disable safe mode in Windows ME? I looked in msconfig but I didn't see an option to disable safe mode.
    24 y/o w/ Silver/Red
    2000 Honda S2000
    http://www.squeezer.net
    There is a piece of software I think it is called Xsetup that is similar to TweakUI only about 50 times as many options.
    http://www.xteq.com is the site but I got it from download.com (I think)
    http://www.geocities.com/mr_bubba_zanetti/
    current projects
      I have used the XSetup software before and there isn't an option to disable safe mode, only an option to disable scandisk.
      2000 Honda S2000
        errr these are msdos.sys settings
        check out the webpage
        http://www.physiol.ox.ac.uk/~trp/msdossys.html
        look at the info on bootwarn, BootMenuDefault, and maybe BootSafe also (info from the url included below)
        I would test these out to see if I could figure out what you need from it but I am at work and only have my win2k machine to work with so I cant do that right now.
        BootWarn=
        Default: 1
        Purpose: A setting of 0 disables the safe mode boot warning message and
        the Startup menu.
        BootMenuDefault=
        Default: 1 if the system is running correctly
        3 if the system hung in the previous instance
        Purpose: Use this setting to set the default menu item for startup.
        BootSafe=
        Default: 0
        Purpose: A setting of 1 forces your computer to boot in safe mode.
        [This message has been edited by moxnix (edited 02-12-2001).]
          ur right, Xsetup has a lot of options but not to disable safe mode.
          current projects
