Keypad Hexidecimal Values
  • Keypad Hexidecimal Values
    Does anyone have the hex values for the keypad of a 101 key board? I am remapping my keys for MPXPLAY, and have not been able to find the value for the period (.) key on the keypad. It is not reacting to the same hex value as the regular period key.
    KG6OQD
    www.americansandassociation.org
    I think on a standard keyboard that is also labeled DEL and it uses the same scan code as the DEL key 0x53 so give that a try.
      I did that, and it did not work
      KG6OQD
        Ok then try this software I found that can tell you the scancodes when you press the key maybe it can figure out what key it is.
        Keyhook
