auto login...
  • auto login...
    How do i make windows 98 log me in automaticly ?
    you can either open up your network properties in control panel and select "Windows Logon" under Primary Network Logon, which would disable the username and password altogether, or you can get tweakui (you can find it in powertools at microsoft.com i believe), and that will allow you to specify a name and password to log you on at boot.
    ghetto suitcase player: http://www.mp3car.com/usersites/nipkick
      by the way, this solution is only for network logon. if you are using an actual windows98 login, i'm not sure how to disable that. i guess you can mess with it in the "users" part of the control panel.
        Thanks alot. works like a charm =]
        right now i have it running next to me inside but soon it will get a test run in the car...
