Controlling a pc using a plam top ce device
  • Controlling a pc using a plam top ce device
    Hello everyone!
    Well I know this has been covered using the pc anywhere for ce. But, on my hp 320 lx I can not for the life of me get ce anywhere to work. I was wondering if there is anything out there like http://www.giantdisc.com/ but for windows ce instead? A program that conencts to a computer via and the pc is used to played mp3s and controlled via the handheld device. Anyone heard of such a project? Check out <A HREF="http://www.giantdisc.com/!!!
    " TARGET=_blank>http://www.giantdisc.com/!!!
    </A>
    -Jason
    Car
    1964 Ford Falcon powered by a 1993 Mustang 5.0 EFI, AOD transmission, with disc brakes up front and more mechanical goodies
    The Player
    Gone! Soon goign to repalce the screen based system i HAD with an iPod. http://mp3falcon.crazyshaxs.com
    Use VNC instead. See http://www.uk.research.att.com/vnc/ for info.
      nice... Ill have to download it and see if it will run on my hp 320.
      -Jason
      Car
      The Player
        With a windows CE machine you can use the webbrowser to run giantdisc. Set up a proxy on the serial port and open Pocket IE. Done deal...should work great.
          What's giantdisc?
            see my first post.
            -Jason
            Car
            The Player
              byaroch, have you tried getting the giantdisc software to work like this?
              -Jason
              Car
              The Player
                I have not tried it. I would need a nic and a PC with the software on it.
                However I don't see why it wouldn't work.
                Also I looked at the scripts....it should be fairly easy (for someone with programming expirence) to make a CE version of giantdisk.
                Do we have any takers? (should be easy to impliment with embedded VB)
                  You might want to try this
                  http://www.cs.utah.edu/~midgley/wince/vnc.html
                  you could run winamp on a pc and VNC into that machine
                    I use palm amp.
                    I have looked at vnc.But I cant get it working verry well over the serial port.
                    I also have some software called pebbles PC http://www.cs.cmu.edu/~pebbles/
                    They all do verry similar things.
                    Except palmamp is really a customized interface to winamp.
                    Gizmo-
                    Techonlogy on Wheels
                    http://www.hjnetworks.com/car
                      Originally posted by crazyshaxs:
                      <STRONG>see my first post.
                      -Jason</STRONG>
                      Oops...I'm an idiot sometimes.
