VB6 Folks.. Perhaps a little help
  • VB6 Folks.. Perhaps a little help
    Okay. Im taking a crack at my own player. I'm a decently experienced coder, but I'm stumped. Perhaps I am too close to the problem to see clearly.
    Anyway, I'm working on an idea to use a TreeView control to explore directory structure and MP3 in the same window. Idea is to work with TreeView with checkboxes, so I can check songs and whole directories and for example add them all to a playlist, queue, etc.
    I've tried numerous TreeView Controls. Current control is from VBAccellerator.
    Code:
    Option Explicit
    Private m_cIml As New cVBALSysImageList
    Private m_lID As Long
    Private m_shl As New Shell
    Private Sub Form_Load()
       ' Create a System Image List:
       Set m_cIml = New cVBALSysImageList
       m_cIml.IconSizeX = 16
       m_cIml.IconSizeY = 16
       m_cIml.Create
       tvwDirs.ImageList = m_cIml.hIml
       ' Enumerate the shell's desktop folder for files
       Dim drives As Folder
       Set drives = m_shl.NameSpace("E:\ripped")
       Dim driveItem As FolderItem
       Dim nod As cTreeViewNode
       Dim count As Long
       Dim sKey As String
       For Each driveItem In drives.items
          If (driveItem.IsFolder) Then
             m_lID = m_lID + 1
             sKey = m_lID & ":" & driveItem.Path
             Set nod = tvwDirs.nodes.Add(, , sKey, driveItem.Name, _
                m_cIml.ItemIndex(driveItem.Path, True))
             nod.ItemData = 0
             m_lID = m_lID + 1
             nod.Children.Add , , "TODO:" & m_lID, "Unexpanded"
          Else
             m_lID = m_lID + 1
             nod.ItemData = 1
          End If
       Next
    End Sub
    Private Sub tvwDirs_BeforeExpand(node As vbalTreeViewLib6.cTreeViewNode, cancel As Boolean)
       If InStr(node.FirstChild.Key, "TODO:") = 1 Then
          Screen.MousePointer = vbHourglass
          node.Children.Remove 1
          Dim items As Folder
          Dim itm As FolderItem
          Dim sKey As String
          Dim iPos As Long
          Dim nodes As cTreeViewNodes
          Set nodes = node.Children
          sKey = node.Key
          iPos = InStr(sKey, ":")
          sKey = Mid(sKey, iPos + 1)
          Set items = m_shl.NameSpace(sKey)
          If Not items Is Nothing Then
             For Each itm In items.items
                If (itm.IsFolder) Then
                   m_lID = m_lID + 1
                   sKey = m_lID & ":" & itm.Path
                   Set nod = nodes.Add(, , sKey, itm.Name, _
                   m_cIml.ItemIndex(itm.Path, True))
                   nod.ItemData = 0
                   m_lID = m_lID + 1
                Else
                   m_lID = m_lID + 1
                   nod.ItemData = 1
                End If
             Next
          End If
          node.Sort etvwItemDataThenAlphabetic
          Screen.MousePointer = vbDefault
       End If
    End Sub
    This should loop and display the subfolders of the base directory on FormLoad.. and it does.
    On Expand of Tree tvwDirs_BeforeExpand should then loop and display subfolders of current node on each expand. and it does not.
    I have no doubt it is a silly syntax issue, but I can't find it.
    Thanks in advance for any help.
    Jack
    wut about writing your own active x.. makes more sense... instead of trying to shape something...
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
      Most likely beyond my current abilities. This should be an easy thing call Shell for base directory, load directories in tree. On each expand, call Shell again and load subdirectories and/or files.
