MPX Play best way to use file that have long file names ?
  • MPX Play best way to use file that have long file names ?
    I am using mpxplay but i am having issues using it due to long file names. Is there a program that will convert playlists and files to short filenames ??
    What have you guys done to get around this problem ?
    Mpxplay reads the MP3 id, the info contained in the MP3, so, it doesn't matter what the file is called..
    You have to enter the info when you make the MP3, or you can change it later using a program called "mp3 file editor" which you can download from http://www.mp3fe.com
      thats not the problem
      the problem is its gona be a pain in the arse to make the play lists
        This page has a Dos long-filename utility that you could try: http://saturn.spaceports.com/~dosuser/dosutils.htm
        http://thecoldfront.com
          Playlists?? MPXPLAY can search for all the MP3s on a certain drive, then make a playlist using the dos names, eg. iamalo~1.mp3...
          I don't think I understand your problem...
            Dr-DOS supports FAT 32 and long file names. It also suports networking, but I've never had any luck getting this going. You can get more info and downlaod Dr-DOS at www.freedos.org.
            Mike.
              I was going to use m3u playlists.
                I did some testing this morning. The "lfndos" utility, that I posted a link to, isn't compatible with MPXPlay.
                I was able to get lfn playlists to work, using:
                MPXPlay 1.44 (Didn't seem to work under 1.42)
                Windows 95's Msdos Mode
                "Doslfn" http://www-user.tu-chemnitz.de/~heha...are/freew.html
