One button shutdown
  • One button shutdown
    Is it possible to have a program for an ATX mobo that when the button is pressed like 3 times in a row or somethin, it will shut down? I'm thinkin that this would be possible considering that the button contacts go into the motherboard. Just interested now cuz I have a ATX mobo in my car! Thanks!
    -Kev
    Im not sure here, but I have heard of something called "shutdown cards". Something you can stick in your computer that controls the shutdown process, so all you have to do is press a button. Im not sure this is what you meant, but it might help.
    - Experience varies directly with equipment broken ---------- Kevmo
      Now that I think about it, you can do it through the serial port. If you look at the back of higher end UPS's (Uninterruptible power supply) they have a serial port and you can buy the cable and software so if it sees that theres no power, it shuts the pc down automatically before the battery on the UPS wears out.
      -Kev
        UPS
        Includes User Manual , Velco Cord Management Straps , Smart UPS signalling RS-232 cable , CD with software
          you dont need anything special if you're running windows:
          start->settings->control panel->power options->advanced
          At the bottom of that window, it says "when I push the power butotn on my computer:"
          choose shutdown.
          Now, when you push the power button, it just shuts down--as long as you dont hold the button, then it just cuts off.
          also, make sure your BIOS is set to a delay on power off. My systems all have a 4 sec delay. with these settings all I have to do is push the power button and the system shuts down. if the system locks up, all I have to do is hold the power button down for 5 sec and it cuts power.
          NOTE: this may be hardware dependent
          Debt as of 1/1/05: $34,354.48
          Debt as of July 4, 2007: $0.00 explanation
          I'M DEBT FREE!!
          I'm now a reasonably successful gunblogger.
            What version of windows are you using? I have windows 98 release 2. That's definitly what I need though. How would I get this option if you have the same OS as me? Is there a way to upgrade power options? Thanks.
            -Kev
              I believe WinME has it too.
              abcd-1
                I dont see that option on WInMe
                  The setting is motherboard/BIOS dependant. Look for a BIOS upgrade. Some older motherboards are sol. You can also hold down your power button and have it shut-off (not windows shutdown).
                  ODYSSEY
                  Originally posted by Tidder
                  Digital-Car UK|
                  (\__/)
                  (")_(")
                    There should be numerous shareware utilities that let you do this. There is a Windows API call for shutdown. I found one at Download.com Called Shutdown Now.
                    JohnRam
                      I have Irman "one button shutdown" method. I just press a defined button on my remote and PC shuts down completly.
                      mpt
                        [Computer Shutdown Shortcut]
                        C:\WINDOWS\RUNDLL.EXE user.exe,exitwindows
                        [Computer Reset Shortcut]
                        C:\WINDOWS\RUNDLL.EXE user.exe,exitwindowsexec
                        i believe these are the shortcuts u can create and bind to a key or button on a remote
                          On Win NT: "C:\WINDOWS\RUNDLL32.EXE user32.dll, exitwindowsex"
                          mpt
