slow bios loading.
  • slow bios loading.
    my bios loading time is really slow like 20+sec.i have a epia V1000. and it sit at the screen that said via MAINBOARD for about 20+sec. and then sometimes it go no boot drive found. help me out thanks
    SPEC of system:
    epia v1000
    window xp sp2
    wd40g hd
    no cd rom drive.
    More information, please.
    What is your primary boot device? CDROM? HDD? CF card?
    Is the PC in your car? On your desk?
    What sort of power supply is it using?
    Really, man. This is like me asking for help because my engine is making a funny noise.
    It reminds me of when I did phone support for Earthlink. Every call started with "I can't get my email". Never mind that some of these people had dead hard drives, a problem more serious than inability to access email. But that's the only symptom they see.
    We can't help you without details, man.
    How about the Wiki?
      primary boot device is my hdd, pc is in my car, and i'm using a 60watt ps from minibox
        Sounds like hard drive or hard drive controller failure to me.
        I have a desktop that has a ton of drives, and bios probes all the hard drives and cd/dvd burners, which slows it down.
        Raid controllers slow it down as well. If you have a raid card, or have onboard raid, disable it if you're not using it, because it'll slow things down dramatically.
        Some drives also degrade over time quite a bit, and when they power on and bios probes them, they are in the middle of a drive head sync, so bios has to wait while it does that before it says "I'm here."
        Try with another hard drive (if you have one).
        Kevin
        Audi A4 Carputer, 80% setup.
          Are not you seeking FDD drive while its not connected?
            heynicecar: Im running the very same stuff as u.. but i got an opus powering it all..
            going into ur bios and try setting it back to the safe settings? see if that works
            were u using hibernation with xp? if so how long did urs take to load?
            View My Blog
            Click for 2GB FREE on-line storage!
              i'm not using hibernation. ill try to change the setting in my bios when i get a keyboard in there. thanks for everyone input.
