POLL: Performance: Speed or Memory usage
  • POLL: Performance: Speed or Memory usage
    Which would you rather consider, a application that has speed benifits and uses slightly more memory. Or an application that uses the least amount or RAM possible but takes a little longer to load each function.
    Crouching Tiger, Drunken Kitty
    Speed!
    Ram is cheap, but cpu-power and disk-throughput are power consuming and physically big...
    Only problem I can think of is hibernation / resume speed if you'd require really much ram.
    List of front-ends/usefull apps
    XTroniC | XTroniC Direct
