AH, PLEASE HELP>>BOOT UP PROBLEMS
  • AH, PLEASE HELP>>BOOT UP PROBLEMS
    ok, this is really weird. I boot up my computer and it asks for the following files: vnetsup.vxd, vredit.vxd, dfs.vxd. Then, when windows 98 SE loads up it states that msnp32.dll is missing....everything seems to work fine though. Anyone help me out?
    Also the stupid computers really wants a flopy drive...but it isnt going to get one, is there a way to configure the bios to not search for the flopy?
    thanks
    Computer:
    FV24
    custom plexi case
    p3 650
    6.4 lcd
    everything working...except stupid lcd isnt working with shuttle board
    Sounds like you need to reinstall Win98SE, or maybe you deleted a program wrong and it is looking for files set in the start-up files. Reinstall 98SE if that doesn't help, then run "msconfig" or another utility that displays the stuff in startup.
    Look through your BIOS for "Floppy seek on boot", or just disable everything to do with the floppy.
    http://www.mp3car.com/usersites/Maveric/ M.A.V.I.C. System
    Asus MB, PII 266, 192 MB Ram, 6.8" LCD, 6 Disk CD-ROM, 21 Gig HD, All-in-Wonder Video w/ TV Tuner, Irman, Windows ME, Winamp, Cobra III -- All in a custom acrylic case.
    http://www.mp3car.com/usersites/listings/ MP3car Listings - Please add to it! :)
      Installing Windoze over the top probably won't help, try it first though, you might have to reformat and reinstall...
        I think this problem occurs when you have a problem with your network and adapters ect. Do you have a lan card? If so, right click on network neighborhood and remove your adapter for your network card. Reboot windows and reinstall all the drivers. This should help, if not, reinstall windows.
        Car
        1964 Ford Falcon powered by a 1993 Mustang 5.0 EFI, AOD transmission, with disc brakes up front and more mechanical goodies
        The Player
        Gone! Soon goign to repalce the screen based system i HAD with an iPod. http://mp3falcon.crazyshaxs.com
          Run regedit and delete the following registry keys:
          HKEY_LOCAL_MACHINE\System\CurrentControlSet\Servic es\VxD\VNETSUP
          HKEY_LOCAL_MACHINE\System\CurrentControlSet\Servic es\VxD\VREDIR
          as dor the DLL it's probably in your registry somewhere too. You could search for the name and see if it is loaded somewhere.
            Hey buddy just format the HDD and reinstall the OS cause if you do a kiss up job and the comp starts to act funny in the car man it sucks!! :-)
            and for the floppy go to the bios setup there you will a option as standard bios setup where the date and the time thing is displayed below is the HDD information and so on there you will find the fdd information also just say none and she wont ask for it again :-)
            Mastero
            [email protected]
              technics is right. delete those registry keys and you should be fine. like crazyshaxs said, you might also want to start in safe mode and remove all your network clients, adapters, and protocols from your network properties. then reinstall those you need. there is no need to format and start from scratch.
              for the msnp32 thing, run sysedit and get rid of the section in system.ini that says msnp32. not sure if that does it or not, but i know there is alot of msnp32 stuff in the registry. whatever you do, just make a backup of the registry and delete what you want. if you mess up, start in safe mode and restore the backup of the registry.
              jeremy
              [ 10-24-2001: Message edited by: jstrain ]
                Don't reinstall the OS, and don't reformat. You don't need to. First, copy alll the CAB files from the Win98 CD onto your HD. Then, in Network Properties, remove everything. Reboot. It will redetect the network card (assuming PNP) and want to copy the files from the Win98 CD. Point it to the directory where your CAB files are located. Once things are installed, reboot and remove everything from Network Properties again. Then reboot and let it redetect. If it wants the files, again point it to the CAB directory. Reboot, and problem should be solved. 10 minute operation.
                  Yeah I had this problem at first, goto the microsoft support site and type in one of those file names, you'll find an article about extracting those files from the windows cd. This fixed it for me, but then I had to re-install windows again anyway... So either way you can just pull them from the cd or redo it all. http://support.microsoft.com/directory/
                  [ 10-25-2001: Message edited by: CaffeineAddict ]
                  Josh Karger
                  By reading this post you agree to overlook all grammatical, spelling, and typographical errors! ;)
                    THANK YOU SO MUCH, i deleted the reg. keys and it works fine now. Thanks!!!!!
                    Computer:
                    FV24
                    custom plexi case
                    p3 650
                    6.4 lcd
                      Just so you know, those are all network related files, a VERY simple way of doing this, without the registry, is, network neighborhood properties, and delete all networking components, reboot, it will attempt to reinstall the ethernet cards, when done, you'll be fine.
                      http://www.mp3car.com/members/tracke...ivic-2007.html for Car Pics!
                      http://www.mp3car.com/vbulletin/lcd-...ease-read.html for Touchscreen timeout fix!
