delfolder.exe
  • delfolder.exe
    I don't get it, I've had to delete and re-install XP 3 times now and I can't get rid of this "unable to locate file: c:\windows\systblah\delfolder.exe"
    I've deleted evertyhing concerning it in regedit and now this last time I can't even install windows now.. what gives?
    [------|-] 95% computer... is it ever really done?
    www.vehicross.info for all you VXer's
    run hijackthis and see whats trying to access it
    does it do this in safemode?
    PC Components:
    My work log
      msconfig...
      it's probably being started on boot. click start > run > type "msconfig" > "startup" tab and look for an entry that has delfolder.exe listed. take the tick out of the box, reboot, voila.
      good luck!
      http://www.nerdybynature.com
        what do you mean by "delete and re-install XP"? Are you reformatting the drive? Because if you are then you should not be having any problems on a fresh XP install...
          try this - http://www.talkroot.com/archive/topic/9943-1.html
          Laidback
          The ultimate CarPC - Wow!
