lorty's mp3car winamp plugin v.2.20 FREE!
  • lorty's mp3car winamp plugin v.2.20 FREE!
    Now you can download version 2.20 of my plugin from <a href="http://lorty.mp3car.com" http://lorty.mp3car.com </a> . It's freeware, since I decided to ask registration only for customized versions.
    Lorenzo
    If you haven't downloaded this, you should. It is really nice. But if you do...you'll probably have to change the speed of the EQ to about 13-15. At 20 it's so fast that it hardly shows on mine.
      hitachi controled means it uses the common hd44780 controller ?
        hmm yeah..probably yes. this plugin uses the same wire layout to hook up to the paralell port just as the inmotion lcd ?
          yes it uses the same inmotion layout
            now you can register a custom version of my plugin directly online from www.mp3car.com
            follow the "View the new products, in the online order section" link from the www.mp3car.com homepage.
            Thanks for all your support,
            Lorty
              Wow ... guyz if ya running windows -setup ..
              this is a must ... it even turned my 16x2 LCD
              into a complete visual control unit ...
              has all the features you will ever need
              Good work Lorts
                The registred version now has infrared control (irman and UIR) trough an external program; it is also compatible with VFDs (2nd and 3rd lines reversed). Startup speed also is way faster.
                <a href="http://lorty.mp3car.com">http://lorty.mp3car.com </a>
                Thanks for all your support.
                Lorty
                [This message has been edited by lorty (edited 04-19-2000).]
