Quicky Programming ?
  • Quicky Programming ?
    Argh I was wondering if you guys could help me out here. I've ben stumbling over this code for a few hours and I'm willing to bet one of you have the anwser. Any help would be great !
    ok, I'm using VB.Net and I for the life of me cannot convert this vb6 code:
    Code:
    Sub timeout(seconds As Double)
    Dim total As Double
    Dim current As Double
    Dim X As Double
    X = Timer
    Do
    DoEvents
    current = Timer
    total = current - X
    Loop Until total > seconds
    End Sub
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    Code:
    Dim total As Double
    Dim X As Double
    X = Timer
    Do
    DoEvents
    current = Timer
    total = current - X
    End Sub
    What is "Timer" ???. Don't see it declared . Are you just trying to loop for a certain amout of time and still process events ?
      VWmike, if your not familiar with VB6 then dont try to answer it....timer is the current cpu clock time
      PC Components:
      My work log
        i think this is close
        Imports System
        Imports System.Threading
        Public Class Form1
        Inherits System.Windows.Forms.Form
        Sub timeout(ByVal seconds As Double)
        Thread.Sleep(seconds * 1000)
        End Sub
        End Class
        PC Components:
        My work log
          nope :-\ grrrrrr this is such an easy thing
          Via EPIA MII
          512MB RAM
          OEM GPS (embedded)
          nLite WinXP pro on
            here it is exactly
            Dim x, current, Total As Double
            x = Microsoft.VisualBasic.DateAndTime.Timer
            Do
            Application.DoEvents()
            current = Microsoft.VisualBasic.DateAndTime.Timer
            Total = current - x
            Loop Until Total > seconds
            End Sub
            PC Components:
            My work log
              awesome.
              Awesome.. thats where they hid the timer.... thanks a bunch !
              Via EPIA MII
              512MB RAM
              OEM GPS (embedded)
              nLite WinXP pro on
                no prob
                PC Components:
                My work log
