Login
  • Login
    I have a slight problem that maybe you guys can help me with. I have a network card installed and when my sytem loads up i get the network login. My question is if / how can i have it so it automatically logs in. I don't want to remove it cause i will need it to transfer files from my main system to my mp3 machine. thanks.
    In network properties choose windows logon as the primary log-on. Also set no password under the passwords applet in control panel.
    That should do it
    http://www.mp3goesmobile.com
    http://mp3mercury.mp3car.com
    <A HREF="http://mp3mercury.ghettoware.net[/URL" TARGET=_blank>
    [URL=http://mp3mercury.mp3car.com]http://mp3mercury.mp3car.com</A>
      Or use the TweakUI to set a autologon. It does the following Registry Changes.
      [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Winlogon]
      "DefaultUserName"="<Name>"
      "DefaultPassword"="<Name>"
      "AutoAdminLogon"="1"
        Best idea is to go to the system properties from the control panel, goto the network card properties and disable it. #1 this will take care of the login problem, #2 it will also add some boot time as I am sure you are probably being stalled up for probably about 20-30 seconds just because it is looking for the network connectoin. Then when you need to use the network card again, just goto the system properties, and uncheck the disable choice.
        Grand Am-P3
        The Grand aMP3 Project
        Car: 96 Pontiac Grand Am
        Current Setup: AMD K62 300MHz, 64MB DIMM RAM, 20GB WD Hard Drive, Basic Video & Sound
          Hey,
          Well the problem with that is that if i disable it i will have no way to enable it via network without a screen. I need the network to transfer files. I suppose i could transfer disk to disk. I'm still looking for a lcd or display in my area and i have yet to be successful ( montreal ). I know they have online but i don't really feel safe sending money. But ya i could disable it and remove the login at beginning. thanks.
            Just install a program called TweakUI. It will let enter in you net logon without a prompt. Can be found at www.download.com.
            Hope that helps,
            aka_Lint
