Windows 3.11 ??
  • Windows 3.11 ??
    Anyone use windows 3.11 with sucess in their mp3 car player? I would think that it would load faster. And scandisk would not be a problem. Any info would be nice
    ~meron
    I thought about it but decided not to because of the software support. Windows Media Player (the core software in my player...details to follow in a few weeks when the whole thing is completed) is available, but crippled. I couldn't use 32 bit VB to program, which eliminated ActiveX, which is how I control Media Player. Windows 3.1x is also not the best multimedia platform and can be a little unstable (depends on the software). Also, you have the FAT16 limitation, meaning you can't use a drive larger than 2Gigs (2048MB) without having multiple partitions. And at that size FAT16 is very innefficient.
      I thought about using Win3.1 too because I found a StreetAtlas USA CD at Goodwill and thought it'd work great with the LCD. But DOS is still the better choice because it boots faster, it's stable, and it's small. And DOS is extremely easy to program for. Less conflicts and crap to have to worry about.
      Good points about Win 3.1:
      It's multitasking
      More software
      Bad points about Win 3.1:
      MS made it
      FAT16
      Boots slow
      MS made it
      Gutter http://impee3.hypermart.net
      The Impee3 Car Player
      Don't Click
        Um, this may be a surprise to you, but MS made DOS too. (since you seemed to think DOS was a good thing, but MS made stuff isnt =)
        Anyway, I cant think of any Win 3.1 MP3 players programs, or any way to control it that is specificly Win 3.1. So you woud either have to write everything yourself, or boot to win 3.1 but use DOS programs like mpxplay, and for that it woul be better to just use DOS.
          Not that I'm all for using Win3.1, but...
          You can still use FAT32 with Win3.1:
          1) Install the disk drive as the slave in a Win98 system.
          2) Use the FDISK utility and partition the drive as FAT32
          3) Format the disk from Win98 explorer and tell it to copy the system files.
          4) Make a directory called DOS on the new drive and copy everything from c:\windows\command on the Win98 boot drive to the DOS directory you just created.
          5) Switch the new disk to be primary master.
          6) Reboot
          7) Install Win3.1 from floppies or CD.
          Now you have a bootable Win3.1 system with FAT32!
          You can also install a patch for Win3.1 to make it able to run 32-bit apps, it's called WIN32.
          Anyway, I haven't tried actually doing this, but I just wrote this to show that it is _possible_ to use Win3.1 with FAT32 and run 32-bit apps. After all, it does multitask better than DOS and boots a lot faster than Win95/98
          --Jason
          Web site: http://www.m2pc.com
          Yahoo Pager: m2pc123
          Jason Johnson
          Yorba Linda, California
          http://www.m2pc.com
          MPC Phase IV - *** PENDING ***
            Has this been done? I think I'll try that out. If I can run 32bit apps, then it should work out great. I can make a VB player that would look a lot better than anything I could write in C.
            Don't Click
              I mean C in DOS.
              Gutter
              Don't Click
                i think this post should have been put into software discussion...i'm not trying to be an ***, but it is definitely not a hardware related issue
                  You can run SOME 32Bit apps in Win 3.1, not all. Exclude any 32Bit app that uses ActiveX, which is most of them nowadays.
                    You can't really use VB to make 32bit apps to run in 16bit Windows with Win32s installed. I can't imagine writing the low level code required to decompress an MP3 in VB, so I would assume that you would be using the Media Player COM object or something similar. This can't be done under Win 3.1 even if Win32s are installed as it does not support ActiveX (it does do OLE, which is an older standard similar to ActiveX, but ActiveX is not backward compatible). Use a stripped down version of Win95.
                      I downloaded some multimedia libraries a while back for VB6 that include a mp3 decoder, spectrum analyzers, and a bunch of other crap. I don't think it uses ActiveX, but then again, I could be wrong.
                      Gutter
                      Don't Click
                        Can't you just create a Win31 frontend for a DOS mp3 player like DAMP or MPXPLAY? MSs media player would never come into the picture.
                        Gutter
                        Don't Click
                          I have transferred this forum from hardware to software as was suggested.
                            Of course. But then you could skip the whole Win32 thing and just use 16 bit VB...
                              I found some mp3 players for 3.11 at download.com if that helps anyone.
