which front ends can run @ 640x480 ?
  • which front ends can run @ 640x480 ?
    i don't know if it's a common problem or not ... but I'm interested in know what all front ends support 640x480 ?
    thanks for the info!
    what do you want to know? "what all frontend support 640x480"...
    I think you mean one of two things (with answers)
    "WHY all frontends support 640x480" A: because people use that resolution, and it is usually driven by a skin
    "what forntend supports 640x480" A: I think all or all the actively developed ones at least... These are all run with skins and you will need to find a skin that is in that resolution. You can use RR which will automatically resize skins to whatever resolution you choose. NeoCar will also auto-size skins for any resolution
    Roy
    2005 Range Rover 4.4
      All of them.
      [H]4 Life
      I'm a lesbian too.
      I am for hire!
        Centrafuse doesnt unless someone makes a skin for it.
        2000 Sunfire build 100%, or is it ever really 100%?
          All of them except RR and NMC need the skin to be made specifically for that resolution I think
          Roy
            FP doesnt need the skin made to the exact res either.
              CarBox can scale any skin to any size. I'd guess most others can too.
              GingerPrince
              Car changed for TVR Griffith 500, so computer de-installed. Using a Dension 100ix w/60Gb HD unit in the interim.
              Carputer Install - http://www.stuffandting.com/carputer/
              CarBox Software -- http://www.stuffandting.com/carbox/
                I'm sure my RR can resize the skins, I'll double check in the car tomorrow
