Volume Problem
  • Volume Problem
    On Winamp I can only go as low as 13% volume. Below that level no sound comes out at all. I am using a sound blaster 16 card. I have an AWE 64 card, should I use that instead ? Thanks for any help.
    i don't think that has anything to do with winamp....check your main volume control
    abcd-1
    abcd-1
      I tried the main volume control but it still produced the same results. I am going to try changing the sound card tonight.
        uhhh unless I am missing something here: why does it matter anyway. Just stick the winamp on %50 and use your headunit to amplify
        Car: 1999 Dark Green Mustang GT Coupe
        Audio: Alpine HU, JL 6ch Amp, JL Stealthbox and XR series components.
        Player: Empeg for now; something custom later.
        www.neotechpc.com - Custom built laptops!
          I have no head unit it is wired through a combo amp/eq. So I have to use winamp to control the volume.
                I have exactly the same problem and the same sound card, sb vibra 16, its really a cheap sound blaster...But with that combination pc->amps, we dont have a decent volume control...i am thinking of adding an analog volume dial and leave winamp at about 75%...any ideas are welcomed...
                  I switched cards to the AWE64 and it worked. I have complete control of my volume. Also the sound is so much clearer.
