VisualDesigner for creating other skins
  • VisualDesigner for creating other skins
    Hi folks,
    I've added some code to (PhoCo's) VisualDesigner to make it a bit more versatile.
    By applying the command line parameter -Other=xxx users are now able to create a new design from scratch by adding controls (Buttons, Panels, Listboxes) and export that new design to any format needed.
    The export constsist of two major functions:
    1. All elements on the main form will be merged with the background and saved as two bitmaps (Jpeg or Png), one for the normal state and one for the clicked state.
    2. A Export-Provider is called (using COM) and all elements contained on the form will be reported to the Export-Provider. The provider is responsible to create a customized INI file that can be used with any other application.
    Since the design is not only exported but also saved in a VD format (XML), designers are able to reload the skin and apply changes whenever needed very quickly.
    At this stage, there is only one sample Export-Provider which doesn't really do anything but shows how to use it.
    Developers who are interessted in making Export-Providers for their apps, please let me know.
    Designers can use is to create / edit skins for any app but they have to wait for Export-Providers to become available.
    Here's a short instruction what you gotta do to get this VD version:
    • Download and install the latest version of PhoneControl.NET if you didn't already (VD is a part of it)
    Skinning to go... VisualDesigner2!
    Looks awesome! But can we also get a permanent clicked state? So say if we're having relays that are on, you don't want the button to turn to the original state. Then that would require 2 more images
    This would be a great way to create "universal" skins
    PowerVoice v1 | NaviVoice Source
    GammaControl v2.4
    SKINbedder v3
    1995 Lexus SC300
      What is the difference between a clicked state and a permanent clicked state (seen from the graphics side)?
        Well, say that you have an "LED" on one of the buttons to know if a relay is on.
        GammaControl v2.4
        SKINbedder v3
        1995 Lexus SC300
          Well... think about... I'm sure you'll find the answer.
            Hopefully
            This project would really help me. My skin designer suxed.
            BTW: Exporting to INI won't be required.. right?
            GammaControl v2.4
            SKINbedder v3
            1995 Lexus SC300
              No, this is just a suggestion. Whatever the Export-Provider does, this is up to you.
                Great! Can't wait to test it
                My email
                GammaControl v2.4
                SKINbedder v3
                1995 Lexus SC300
                  Seems pretty cool. So, if I understand correctly, you can use this to export skins to any other program, and then simply use the exported file in another program? I would love to try it out, I've been looking at some way to do this, as opposed to using a skinner made to work with one program, and then going back to edit the whole file to work for mine.
                  My email.
                  2000 Subaru OBS
                  Dell P3 @ 900 Mhz
                  7" Lilliput TS w/DigitalWW in-dash mount
                  80GB External HD
                  I am Zero Bitrate....
                    Some suggestions:
                    Have create buttons/listboxes/etc on a toolbar.
                    I didn't really find a setting for a "selected" image. Some designers use just 2 images, and create "hotspots" on the forums. I'm guessing that a panel can act as a hotspot.
                    The scale mode also doesn't work, just as you said:
                    Code:
                    See the end of this message for details on invoking
                    just-in-time (JIT) debugging instead of this dialog box.
                    ************** Exception Text **************
                    System.ArgumentException: Invalid parameter used.
                       at System.Drawing.Bitmap..ctor(Int32 width, Int32 height, PixelFormat format)
                       at System.Drawing.Bitmap..ctor(Int32 width, Int32 height)
                       at System.Drawing.Bitmap..ctor(Image original, Int32 width, Int32 height)
                       at System.Drawing.Bitmap..ctor(Image original, Size newSize)
                       at PhoneCtlDesigner.frmMain.pnlWindow_Resize(Object sender, EventArgs e)
                       at System.Windows.Forms.Control.OnResize(EventArgs e)
                       at System.Windows.Forms.Panel.OnResize(EventArgs eventargs)
                       at System.Windows.Forms.Control.OnSizeChanged(EventArgs e)
                       at System.Windows.Forms.Control.UpdateBounds(Int32 x, Int32 y, Int32 width, Int32 height, Int32 clientWidth, Int32 clientHeight)
                       at System.Windows.Forms.Control.UpdateBounds()
                       at System.Windows.Forms.Control.WmMove(Message& m)
                       at System.Windows.Forms.Control.WndProc(Message& m)
                       at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
                       at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
                       at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
                       at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
                    ************** Loaded Assemblies **************
                    mscorlib
                        Assembly Version: 1.0.5000.0
                        Win32 Version: 1.1.4322.2032
                        CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
                    PhoneCtlDesigner
                        Assembly Version: 1.1.1939.40187
                        Win32 Version: 1.1.1939.40187
                        CodeBase: file:///C:/Program%20Files/PhoneControl.NET/PhoneCtlDesigner.exe
                        CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
                    System
                        CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
                    System.Drawing
                        CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
                    Infragistics.Win.UltraWinToolbars.v3.1
                        Assembly Version: 3.1.20041.15
                        Win32 Version: 3.1.20041.15
                        CodeBase: file:///C:/Program%20Files/PhoneControl.NET/Infragistics.Win.UltraWinToolbars.v3.1.DLL
                    Infragistics.Shared.v3.1
                        CodeBase: file:///C:/Program%20Files/PhoneControl.NET/Infragistics.Shared.v3.1.DLL
                    Infragistics.Win.v3.1
                        CodeBase: file:///C:/Program%20Files/PhoneControl.NET/Infragistics.Win.v3.1.DLL
                    Infragistics.Win.UltraWinDock.v3.1
                        CodeBase: file:///C:/Program%20Files/PhoneControl.NET/Infragistics.Win.UltraWinDock.v3.1.DLL
                    Accessibility
                        Win32 Version: 1.1.4322.573
                        CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
                    System.Design
                        CodeBase: file:///c:/windows/assembly/gac/system.design/1.0.5000.0__b03f5f7f11d50a3a/system.design.dll
                    System.Runtime.Serialization.Formatters.Soap
                        CodeBase: file:///c:/windows/assembly/gac/system.runtime.serialization.formatters.soap/1.0.5000.0__b03f5f7f11d50a3a/system.runtime.serialization.formatters.soap.dll
                    System.Xml
                        CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
                    zyg9noqk
                        Assembly Version: 0.0.0.0
                    zControls
                        Assembly Version: 1.0.1939.35709
                        Win32 Version: 1.0.1939.35709
                        CodeBase: file:///C:/Program%20Files/PhoneControl.NET/zControls.DLL
                    Microsoft.DirectX.DirectSound
                        Assembly Version: 1.0.1901.0
                        Win32 Version: 5.3.0000001.1126 built by: DIRECTX
                        CodeBase: file:///C:/Program%20Files/PhoneControl.NET/Microsoft.DirectX.DirectSound.DLL
                    System.Drawing.Design
                        CodeBase: file:///c:/windows/assembly/gac/system.drawing.design/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.design.dll
                    ************** JIT Debugging **************
                    To enable just in time (JIT) debugging, the config file for this
                    application or machine (machine.config) must have the
                    jitDebugging value set in the system.windows.forms section.
                    The application must also be compiled with debugging
                    enabled.
                    For example:
                    <configuration>
                        <system.windows.forms jitDebugging="true" />
                    </configuration>
                    When JIT debugging is enabled, any unhandled exception
                    will be sent to the JIT debugger registered on the machine
                    rather than being handled by this dialog.
                    GammaControl v2.4
                    SKINbedder v3
                    1995 Lexus SC300
                      OK, just confirming, this will let me make the buttons inside the designer? Hmm.. I think you have been reading my other posts!
                      Guino..... Time to stop coding RR and code a export-provider for making skins for rR....
                      Roy
                      2005 Range Rover 4.4
                        Kind of... you still have to make the graphics by yourself (or get them from elsewhere) because VD is no drawing tool.
                        But as you know from PhoCo, you can move them, size them, hide/show them apply a caption and other stuff.
                        With the right Export-Provider, you event don't have to put the coordinates into a .skin / .ini file anymore.
                          I cant run the editor... always get this error straight after running "Phonectldesigner.exe -Other=test" or even without the -other tag....
                          already regged the dll...
                          Roy
                            Did you copy it to PhoCo's installation dir?
                              ops... now its working! hhehehe
                              Roy
