software to read/write to 8 DS1621s
  • software to read/write to 8 DS1621s
    I need software to read 8 DS1621s.
    If you find it online I'll give you a cookie.
    If you write it for me I'll build you a board with connections for 8 sensors and specified wire lengths.
    I also need it to be able to write the Talarm value
    and also work in WinXP Pro.
    Mmmm ... Cookie ...
    Schematic/Code (VB6)
    Caputer Mk. II
    '02 VX Holden Commodore Series II Executive
    MII12000, 512MB RAM, 60GB HDD (5400rpm), 16X DVD, TS200V
    Morex 60W DC-DC, Custom S/SDC
    OS/Software: Developing...
      they have a pretty simple SDK with loads of examples for different programming langs!
        Originally posted by OdysseyPC
        Mmmm ... Cookie ...
        that only reads 2 sensors
          My bad, I assumed you knew a little about electronics. I can let you know how to add the remaining six if you like.
          Hint: The DS1621's use a two wire interface for communications (SDA, SCL). You'll notice from the schematic that these are common to both U1 and U2. Secondly to distinguish between each device attached to these to lines an address is passed when communicating. This address is set by the pin A0, A1 and A2 on the DS1621's from the circuit U1 has A0,A1 and A2 tied like, in binary with A2 being most significant yields 000 (0 in decimal). U2 has A0 tied high with A1 and A2 tied low, in binary this is 001 (1 in decimal). Below is how the rest of the six devices.
          A2 A1 A0 Sensor No
          gnd gnd gnd 0
          gnd gnd vcc 1
          gnd vcc gnd 2
          gnd vcc vcc 3
          vcc gnd gnd 4
          vcc gnd vcc 5
          vcc vcc gnd 6
          vcc vcc vcc 7
          I think that should help you out ...
          Caputer Mk. II
            I know how to wire it, I don't know how to have the software read it!
              Ahhh I see ... I could modify the software for you to read all 8 DS1621's ...
              ... you got PM.
              Caputer Mk. II
