How to write software to interface with hardware?
  • How to write software to interface with hardware?
    OK...this question may be way out there, I'm just looking for a general answer...I have a Engine Management System that uses a serial output to connect to my laptop. Using the supplied software (DOS based) it communicates with the EMS and I can do things like change settings, read outputs, etc...
    My questions is:
    1) Is it possible to write/code my own software to interface with the EMS to display the outputs (i.e. water temper, boost pressure, air intake temp) to a windows GUI-type display? (say to integrate into a program like CentraFuse).
    I don't need an instruction manual (not yet anyway), but a brief idea on how one would go about doing this.
    Thanks!
    yeah its pretty easy, serial comms in delphi isnt hard at all, then its just a matter of prasing strings as they come in.
    have you got a log file on what is coming in? send it too me i'll see what i can do.
      yeah, it is pretty easy if you can get documentation on what is being sent over the line. A bit harder would be to reverse engineer what is being sent over the line, especially if you the communication is two way.
      nice car pate60
      |V1 Virtual Display|
      Hard work often pays off over time, laziness always pays off right now.
        http://www.sysinternals.com/ntw2k/fr.../portmon.shtml
        StreetDeck.com Developer (I am Chuck)
        Get StreetDeck at http://www.streetdeck.com
        The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
          Frodo is working on some skinnable software for gauges. You'll be able to make a plugin for it that monitors your EMS
          PowerVoice v1 | NaviVoice Source
          GammaControl v2.4
          SKINbedder v3
          1995 Lexus SC300
            What is required to develop the plugin? Does it still require I log the serial as described above and develope the proper software/code? Thanks!
              Its not out yet
              GammaControl v2.4
              SKINbedder v3
              1995 Lexus SC300
