Good article on programming an LCD with .NET 2.0
  • Good article on programming an LCD with .NET 2.0
    http://msdn.microsoft.com/coding4fun...D/default.aspx
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
    Search Helpers:
    Programming LCD Displays, LCD, USB LCD, crystal LCD, C# LCD
    P.S. SF, awesome article good find my friend.
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
      Wow, great find! This should be just the info I'll need to build my own COM port splitter into GPSSecure. Going to be a new ports namespace with 2005!
      Installed.
      -GPSSecure- - GPS Tracking
        Yep, System.IO.Ports in .NET Framwork 2.x makes things like this fairly easy!
        2004 4runner
          there's so much good info on MSDN and the MSDN Blogs. Now they have this, Coding4Fun which has some good stuff as well. Luckily I get to spend a lot of time on MSDN for my job so I get to read all this.
          VoomPC 2
