How to Embed Radiator TV in Visual Basic?
  • How to Embed Radiator TV in Visual Basic?
    Does anyone have any info or examples on how i can make a TV plugin using radiator?
    Dragons plugin is useless and i need to make a new 1 so it's skinnable to embed into frontends so it looks like it's apart of it.
    I'm not asking for code that shows me how to do it (altho id love to have it)
    Id like someone to point me in the right direction for embedding it in Visual Basic
    If anyone can help please do
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
    response
    Search msdn for "Direct show" & TV tuner
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
      will do mr intella
      CarPC Status:
      GPS: 99%
      Hardware: 99%
      Software: 92%
      Case Install: 99.9%
      Dash Install: 100%
      Car Install: 72%
        Ok i can have video previewing and I can capture bmp images and avi files etc but for the life of me i don't understand the IAMtuner
        I don't get how i can set the channel without bringing up the dialog
        Maybe my minds fried now and i can't do it.
        CarPC Status:
        GPS: 99%
        Hardware: 99%
        Software: 92%
        Case Install: 99.9%
        Dash Install: 100%
        Car Install: 72%
          If U use VB6 take a look at this library: http://www.nctsoft.com/products/NCTVideoStudio/
            I've got all that working without 3rd party dlls i can capture the tv into a divx file or make some screen grabs i just can't change the channel without using the default dialog
            i know what the khz are of the tv channels i need just son't know how to set them manually.
            this is all by using windows directshow crap no 3rd party stuff like fly2000tv so the tv channels is the only problem i have.
            CarPC Status:
            GPS: 99%
            Hardware: 99%
            Software: 92%
            Case Install: 99.9%
            Dash Install: 100%
            Car Install: 72%
              OK, this is C# code but maby you can port it to VB, this example controls all functions of the TV tuner, and it's directX http://www.codeproject.com/cs/media/directxcapture.asp
                Yeah i found that and found how to manually set the khz of the channel
                http://www.thecodeproject.com/audio/...neTVTuning.asp
                problem is i have no idea how to put that into VB
                i stumbled throught the dshow filters from lots of diff codes around the net.
                Guess its a bit over my head need to relearn vb again
                CarPC Status:
                GPS: 99%
                Hardware: 99%
                Software: 92%
                Case Install: 99.9%
                Dash Install: 100%
                Car Install: 72%
                  I can only tell u to learn C#. You can do so much stuff in C# that was nearly impossible in VB6. I programed in VB for 10 yeas. Now since a few years I do everything in C#, I love it! Take the road to C# via VB.NET if you like (I did)
                  Doing stuff with media like audio/video is easy in C#
                  Whynot download the beta of Visualstudio 2005 and try it out? http://lab.msdn.microsoft.com/vs2005/
                  If you do C#, take a look at this opensource "mediaportal", here you can take some ideas how to do media stuff: http://mediaportal.sourceforge.net/
                    I'll keep trying with Vb and see if i can get it to work if not i'll move on to c#
                    CarPC Status:
                    GPS: 99%
                    Hardware: 99%
                    Software: 92%
                    Case Install: 99.9%
                    Dash Install: 100%
                    Car Install: 72%
                      Could someone do me a BIG favour and give me a hand with setting the tv chan manually in VB?
                      I did try contacting dragon to see if he could update his tv plugin to be skinnable but i didn't get any response at all so please if someone can help me id love u long time lol
                      seriosu i've tried and searched and just can't do it
                      CarPC Status:
                      GPS: 99%
                      Hardware: 99%
                      Software: 92%
                      Case Install: 99.9%
                      Dash Install: 100%
                      Car Install: 72%
