Need Help With Editing .asm (hex) File
  • Need Help With Editing .asm (hex) File
    I have this .asm code which is for PIC16f84 it has four servo control and four digital on/off.
    The file has full description, details and funtions mentioned within.
    What i want is
    a) Someone to modify this file so i can have 6 digital on/off and 2 servo controller.
    b) The servo travels only 90 Deg this should be changed to 180 Deg.
    Your work and time shall be rewarded.
    Kindly mail me your work at [email protected]
    Regards
    Mastero
    it might just be me but with the servos iv used the horn only travels 90 deg. each way from center.
    96' Mercedes Benz C36 -Matte Black-
    Status..::... {##------}25%~~ back to planning
      I dont understand what ur saying ....
      The hex file is for the servo to travel 90 DEG its 45 deg both way ... this should be 90deg both way so we have 180 deg travel ...
      The servo shall never be center
      Mastero
        Thankyou you all for not helping ...!
        Cant belive it not even one person on this forum came forward to help. very sad.
        Neway the work is done
        Mastero
          Maybe because PIC programming is extremely time consuming and tedious unless thats what you do for a living.
            wow, I wish I would have seen this before, I would have helped you out
            肚子笑痛了
            S60 Install
              yah me too. Although i dont know asm
              But i have done pics with c code. Really hard to do timming with c code on a pic though.
              i need to learn asm
              Um, I guess this is where you put something witty.WITTY
              My Web site, in the design stage. http://home.comcast.net/~cstrachn
              Modified RRSkinEditor http://www.mp3car.com/vbulletin/showthread.php?t=65723
